Question about Samsung DVDR120 DVD Recorder
Samsung DVD-R120, can I save what?s on a DVD-R that won?t play?
Accurately recorded (5½ hours) DVD-R disc on Samsung DVD-R120 will not play. Disc finalizing may be the problem, possible double-finalize, how can I correct?…and or retrieve?
  • sparky2770 Jan 21, 2009
    I agree you can not finalize twice…it was taking a very long time to finalize and I mistakenly (re)-finalized it again…although that should have not have let me do it!
    So, if it did allow that to “jam” the finalizing process, how do I save what I recorded?
    The disc will only load in another DVD Player, it says “loading” and never stops.
    Simply how do I recover what I did recorded?
    It was a “one time” opportunity to record.
    Champion:
  • 236 Answers
If it will not play either on the recorder it was recorded on or any other player, you need professional help retrieving the data. There are places where this can be done, but it will probably cost MANY times what the disc does.
Posted on Feb 09, 2009
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
I have a samsung dvd r 120, two dvd's i rented
Is it possible that the region codes of the DVD player and the DVD's are different?
Sep 10, 2009 | Samsung DVDR120 DVD Recorder
Dvd r120
try a new DVD-RAM disc but do not format it,just pop it in and record
May 28, 2008 | Samsung DVDR120 DVD Recorder
Background noise
Check the cables in the back If i remember the Component Red jack is right next to the audio out jacks (also a red jack) if the audio cable is hooked up to the component jacks this will cause a humming static noise
Apr 12, 2008 | Samsung DVDR120 DVD Recorder
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Jul 26, 2007 | Samsung DVDR120 DVD Recorder
Won't Read blank disc!!
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
DVD recoder not recording
I had this problem with my R120, it first wouldn't record and eventually wouldn't play, just gave either an error message or "wrong disc.' Then, another DVD player I own did the same thing.
What worked? I opened them both up and swabbed the laser lens with alcohol and then the clean end of the cotton swab. Now both work like a charm. I figure that all the dirty rental DVDs lowly drop dust and gunk and over a few months the build-up caused failure.
Just to be safe, I also used canned air to remove from inside the unit, around the circuit board and on the lens.
I'd advise leaving the unit unplugged for a day or more to let any stored energy drain and if you're not familiar with safety procedures, take it to someone who is.
Nov 03, 2006 | Samsung DVDR120 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
266 people viewed this question
Henry  Thomas
Henry Thomas
