Question about HP 10s Scientific Calculator
Inverse button hp 10s calculator - HP 10s Scientific Calculator
4 Suggested Answers
  • 7993 Answers
SOURCE: HP 15C calculator display showed
When you get the error press any key to suppress the error message. Put the calculator into PROGRAM mode and you will see the line where the error occurred.
Here is what the manual says for ERROR 4 (free translation)
The line number called is not used or does not exist (larger than 448); attempt to load a program line (instruction) where there is not enough space; line label inexistant.
My hunch is that you are attempting to divide by 0: The quantity of which you are taking the reciprocal (inverse function has another meaning) may have a 0 value.
Do not forget to check the input values.
Hope that will help you debug your program
Posted on Oct 14, 2009
  • 7993 Answers
SOURCE: How do I do an inverse log function on my HP 33s
The inverse of the common log is the raise 10 to a power. the inverse of the natural log is the exponential. The log and the antilog share the same key, one is accessed directly the other as a seconf/shifted function. Same thing for the natural log (ln) and the exponential.
Posted on Feb 20, 2010
  • 102366 Answers
SOURCE: My HP 10s Scientific calculator
You can't charge the calculator off the solar power panel. The solar power panel merely conserves battery power when using the calculator in a bright environment. Try putting in a new battery and see whether the calculator turns on.
Posted on Nov 22, 2010
Find inverse sin
The inverse of a function usually shares the same physical key as the direct function.
Feb 03, 2014 | HP 30s Calculator
Matrix entering and constants
Sorry to be the bearer of bad news, but the HP 10S calculator does not perform matrix calculations.
You have 9 variables A to F, M, X and Y. You can use them to store data, constants, calculation results, and other numerical values.
To store say the value 5674 in Variable A you press the key sequence 5 6 7 4 [SHIFT] [STO] A.
To recall the value stored in A (and use it in another calculation) you press [ALPHA] [A]. It will be displayed and you can do with it any calculation you want.
You can enter (store) data in Statistics modes
  • Mode 2 is for standard deviation SD (1-variable statistics)
  • Mode 3 is for Regressions.
You will have to read the manual starting from page 23.
Sep 23, 2013 | HP 10s Scientific Calculator
How do i change the battery on an hp 10s calculator
Steps
1.Remove the two screws on the back cover using watchmakers screw driver
2. Use a 4mm this flat screwdriver blade and remove the back cover by twisting it
3. Replace the battery [LR55] , put the cover back by pressing and replacing the two screws
4. Your calculator is ready to use
Aug 10, 2011 | HP 10s Scientific Calculator
How can i change the contrast of the display?
Hi ik12364,
The Hp 10s doesn't have contrast control. You probably need to change the button cell battery LR44. This battery only last 3 years, if your lucky under normal use. No telling how long it sat in a warehouse or, on the shelf. If replacing the battery does not work then you may have a defective screen. HP should replace it, if you had it less than a year of purchase date. If you have any more questions about this calculator just post a comment about your inquiry and, I'll be glad to respond.
Jan 13, 2011 | HP 10s Scientific Calculator
My HP 10s Scientific calculator does not switch on what could be the problem, is it maby because the calculator was left in a drawer and now the batery ran flat hou can I charge it on the solar power...
Aug 25, 2010 | HP 10s Scientific Calculator
Where is INV button?
inverse button is used for 2 things
for trig sine inverse for example use 2nd sine
for x inverse use the 4th button down on the far left
Mar 19, 2010 | Texas Instruments TI-83 Plus Calculator
How do I do an inverse log function on my HP 33s calculator?
Oct 19, 2009 | HP 33s scientific calculator Scientific...
User manual for the scientific calculator HP 8s
I can't locate any information regarding an HP 8s Scientific Calculator, but I can locate information on a HP 9s Scientific Calculator. Perhaps they are similar in function. From the HP web site, please check out the link below.
I hope this helps!
- CBR2009
http://h10032.www1.hp.com/ctg/Manual/bpia5267.pdf
Oct 10, 2008 | HP 8S Scientific Calculator
HP 10s Scientific Calculator Logo
29 people viewed this question
Seeker5211
Seeker5211
