Question about Robinair Measuring Tools & Sensors
OIL DRAIN ERROR - Robinair Measuring Tools & Sensors
    Problem Solver:
  • 14 Answers
34700z what it was posted under. The oil drain solenoid is not opening it is located if you open the back pannel of the unit the center cylinder has a copper tube coming out of the bottem. fallow that tube and it will take you to a solenoid. take the solenoid apart and clean the disbre out of it and inspect the plunger for damage.
Posted on Jan 10, 2013
Oil drain error
thee cannot be many measuring tools on the market that require oil to be drained and you would have realized that if you read your post before to submitted it
ask a new question, in the right catagory and include make, model ,year ,type of equipment if you want an answer
Feb 12, 2016 | Measuring Tools & Sensors
What is the right oil and filter to use on the range2007 hse?
How To Change Oil and Oil Filter on Range Rover Sport or Land Rover LR3
  • Place an oil drain pan below the oil filter and drain plug and unscrew the oil filter.
  • Lubricate the rubber seal with clean oil and install the new filter. Tighten to 13 foot-pound torque.
  • Remove drain plug in the oil pan and drain the oil. Catch the oil in the drain pan. After draining the oil install and tighten the drain plug to 18 foot-pound torque.
  • Fill engine with 5W-30 weight oil. The 4.4 V8 takes 8 quarts; the 4.0 V6 takes 6 quarts. Start engine and check for leaks.
  • Recheck level and top up as necessary.
  • Reinstall the under engine shields / skid plates.
Apr 12, 2015 | Land Rover Range Rover Cars & Trucks
Automatic transmission not shifting gears
If have had this problem many times on Mk4 vw golf.
The transmission oil must be fully drained, frop the gearbox sump and replace the filter kit (widley available). Make sure everything is really clean, especially the oil pickup pipe and screen.
I generally measure the oil removed and refill the same amount. you must use the correct transmission oil....so check. I think its dextron3 or similar..but all stockists will have a listing for it.
There is no dipstick , the only way to test is using a scanner or trial and error ( i do not recommend the latter).
Chech vw forums for diagrams showing the drain plug on the sump...you never get all the oil out due to height of the neck and the fact that the torque convertor and oil coolers still have oil in them.
good luck
Roger
Apr 16, 2014 | 1999 Volkswagen Golf
The oil doesn't drain out of my 2001 Harley Davidson Dyna When I remove the oil plug only a half quart of oil drains out. Dipstick is removed and oil is hot.
Are you sure you're pulling the correct drain plug?
On Harleys with the oil tank under the engine, there are usually two drain plugs, oil and transmission drains.
Also, some have a drain on the bottom of the engine, which only a little residual oil will come out of it.
Finally, when the oil stops draining from wherever you're draining from, does the oil dipstick show that the oil level has dropped?
If not, you got the wrong plug!
Aug 07, 2013 | Harley Davidson FXDL Dyna Low Rider...
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
1995 Saab 900S - Engine stops. Oil changed, other
I hope you win your bet but, the drain for the oil is center of the oil pan. There are no other drain plugs near that. They may have drained the differential or transfer case by mistake if that is a front wheel drive. If they over filled your engine oil they should be repairing the engine though. Transmission fluid is red and it would have been obvious they drained that by mistake so I would agree that wasn't what was drained.
Jul 22, 2010 | 1995 Saab 900
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
Oct 30, 2008 | Office Equipment & Supplies
How do you change the oil filter on a Hyundai Accent 1998/99?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
May 23, 2008 | 1999 Hyundai Accent
Open Questions:
Measuring Tools & Sensors Logo
182 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
