Question about Navigon 7100 GPS Navigator GPS Receiver
I've had my Navigon 7100 GPS for 2 weeks now, little use, and today I got the fatal application error that MN6.exe was going to shut down. I have seen forums on this issue but nothing recent. The unit will turn on but only to the point of the Navigon main screen. The hourglass comes up, but is still and then disappears.
  • rwkemper Feb 06, 2009
    I have the same problem. Mine started giving the error message after I updated the maps and checked the preferences last night. The map was zoomed all the way out and wouldn't respond. After I used the reset button to try to get it going again I started getting "Application MN6.exe has performed an illegal operation and will be shut down." I tried restoring a previous backup but it didn't change anything.
  • classic3 Feb 28, 2009
    I have the same problem with the Navigon 7100. I bought this product on line about a year ago. I started to use it recently within the last week and it seemed to be working fine. However, I could not erase a route 34 error or whatever it was called and then I got some kind of error message that was in the form of a yellow triangle warning and I was completely shut down. I had my 7100 plugged into my car while driving and when I got home I decided to charge it again thinking that was the porblem. The system lights up with an hour glass turning up and down. No sound and the unit is completely frozen. What's causing this ? I paid a lot of money for a unit that is not working properly. I will appreciate your help and advice.
    Thank You,
    Alex
I solved this problem.
The backup is just a copy of the files on the SD card. I made one a couple of months ago when everything was working ok. I tried to erase the SD card so I could restore the backup manually. I ran into an error with a SD card file that wouldn't erase. I ended up formatting the SD card then copying the old backup files to it. That took care of the problem and now the Navigon works the way it's supposed to.
Posted on Feb 06, 2009
    Problem Solver:
  • 9 Answers
This can also be caused by a low battery.
make sure your battery is fully charged
Posted on Feb 15, 2009
Application MN6.exe has performed and illegal operation and will be shut down program: mn6.exe eception :0xc0000005 adress:00000000
this is a very common problem with this unit.
What version do you have on your Mio Moov?
I have that error when I run the 2100 version on my Mio Moov. I can run the 7200 software without a problem...
Give it a trial.
Regards.
Jun 13, 2011 | Navigon 2120 GPS Receiver
My Navigon 7100 no longer speaks the street names after I downloaded the latest software updates.
I had the same problem and this fixed it: Connect the navigon to your computer and go into the files directory and create 3 new empty folders, as follows: (You may want to back up your navigon 1st) After i created these empty folders, I was able to go into settings and turn Stree names on
Create these empty folders within MN6\sound folder.
Celine_67_tts
Isabela_22_tts
Sarah_21_tts
May 13, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 7100 stuck on the on screen
It is software problem and i posted solution to that problem it is same as fatal application error problem try that solution your device will up running.
Apr 27, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 2100 mn6.exe fatal error message....going through update with card reader through navigon site didn't work...asme message. machine works. it seems to be card. how do I fix this or get a new...
I got mine back up and working by doing the following:
1st Icopied the files on the SD Card to my pc (for backup)
2nd I deleted all the files on the SD Card
3rd I went to the following link https://www.navigon.com/site/us/en/my_navigon/unauthorized/products_us
and download the update for Navigon 2100 and installed it.
Tested it and it no longer gives me the fatal error.
Jan 07, 2010 | GPS
The MN6.exe fatal Application error is displayed all the time and I am unable to use the Navigon 2100 GPS
push the reset button on the side of the system (a paperclip works well for this). Also, remove the card and put in again. If this doesn't work go to Navigons website and make sure you've downloaded all the software updates. Make sure your unit is fully charged as well. Don't waste your time emailing Navigon's CS online help....I attempted to contact them on 3 separate occassions and never got a response. Good luck. Hope one of my work-arounds helps you.
Dec 20, 2009 | Navigon 2100 Portable GPS Receiver
Black screen - won't turn on
I have put solution to fatal application error try that solution us IE as web brouser.
Nov 29, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
My gps has a fatal application error. Program: MN6.exe Exception: 0xC0000005 address: 002B2110 a
I have application mn6.exe has performed an illegal operation ... on my screen. The system won't go past this
Jan 03, 2009 | GPS
Navigon GPS
if your sd card is OK, there should be an update program on it, you have to go to windows ce on the unit to run this program. to do this hold the bottom right key while booting...
Jul 20, 2008 | Fine Digital FineDrive 400 GPS Receiver
Navigon 7100 GPS Navigator GPS Receiver Logo
1,731 people viewed this question
Top Navigon GPS Experts
roedene
Level 1 Expert
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
