Question about Bissell Vacuums
High wine from my bissell lift-off
A high pitch whine comes from vacuum and loss of suction. No clogs and even ran without the filters with same results.
  • Official Brand Answer
  • 315 Answers
Hey, you may want to have your Lift-Off vacuum inspected by a qualified technician at one of our Authorized Service Centers.
Here's a link to locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Jan 10, 2013
reddevil6
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
SOURCE: Bissell Healthy Home
I had the same issue after using it daily for over a year. I checked everything and found no clog. I brought it to a vacuum cleaner repair center and they found a clog in the motor. It cost me $25 and was well worth it. I love this vacuum
Posted on Mar 01, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Posted on Mar 20, 2008
SOURCE: loss of suction bissell vacume
Under the red flap in the water resevoir, there is a small screen. Pop that screen out and clean it. It is probably blocked with hair. I took my entire machine apart trying to fix this problem and I finally saw that screen. I cleaned it out and my machine works like new now.
Posted on Mar 10, 2009
chrispurs1
  • 372 Answers
SOURCE: noticeable loss of suction, the filter has been cleaned
Hi.
Vortex will be blocked.
Try this site for help http://dysonmanuals.llc.nu/
Posted on May 10, 2009
Ther is no suction in the power tool hose . the soap is dispensed but no suction or at best a very very very faint suction
This sounds like a clogged Lint Filter. The filter (looks like a screen) is located on the Tank Cap. Remove it and clean and put it back. Don't run the unit without the filter. If that doesn't work then try the Flow Indicator Filter (Turn the Flow Indicator cap counter-clockwise to remove it, lift out the rotor and filter. Clean filter and reassemble in reverse order. You can contact Bissell Consumer Care at 1-800-237-7691 for a person to person contact if you need more assistance.
Sep 23, 2015 | Bissell Proheat Upright Carpet Cleaner...
Vacumm loss of suction
Hey! Loss of suction can be contributed to several factors, dirty filters or a clog.
Here is a quick link to our FAQ's to assist you:
http://www.bissell.com/faqs/?cid=ccsocial
Mar 29, 2013 | Bissell Vacuums
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
High pitched noise
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
May 11, 2009 | Bissell 3750 Lift Off Bagless Upright...
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Less suction and high pitch whine while vacuuming
most any vacuum repair shop will be able to remove the obstruction causing the problem
Jul 29, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Mar 20, 2008 | Vacuums
Vacuums Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
