Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
I have the Samsung HDTV Model #4363w..recently the convergence is off like crazy.....They made this model without a manual convergence,and I know the service mode is mute 183.Went in and did it and it cleared up some.In the pattern of the convergence mode with all of the lines,it moves from square to square...how do you know which one is the correct placement of the squares to get it lined up?
  • Samsung Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Samsung HDTV 1080I-Model#HCP4363W-Convergence Prob - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My smasung hdtv 1080i is about 8-10 yrs old. it
you have a convergence problum. The convergence ics go bad about every 6 years
Apr 15, 2010 | Sony KP-53S65 53" Rear Projection...
Technition secret code
To get to the convergence menu pressmute - 1 - 8 - 3 - power
Apr 09, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
XBOX 360 to Samsung HCM5525W high def convergence issue.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Mar 03, 2009 | Samsung HCM5525W 55" Rear Projection...
Double vision on Samsung HDTV 1080i Model PCN542R Need a convergence amp board. Where can I purchase one, and how much is it
Hi .
Its much cheaper to replace the stks on there own.
It may also have a couple of 3.9 ohm resistors cooked.
Nov 17, 2008 | Samsung HCN653W 65" Rear Projection...
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Samsung HCP4363W
when you find out let me know please
Jan 12, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
1,060 people viewed this question
Henry  Thomas
Henry Thomas
