Question about Amana ARB2257CSL Bottom Freezer Refrigerator
Amana arb2257csl waterdispencer not working makes hum but no HTO
Light switch always sticks, so i first pull it or tap it then the light comes on and the water dispencer usually works but now the light turns on but when i push the water button it hums but no water, i put a new filter in and the ice maker works. im not sure whats wrong thanks for any help.
  • 2 more comments
  • richcozz Jan 21, 2009
    should i unplug for a couple of days or is the waterline easy to access thanks
  • richcozz Jan 23, 2009
    how do i access the waterline i cant find manual on line any help finding the manual or how to do it would be appreciated
    thanks
  • richcozz Jan 26, 2009
    i took out the draws in the fridge, i cant find any where to access water line unles its in the roof near the water filter. this model has the water dispencer inside on the left and the freezer is on the bottom thanks for any help
  • richcozz Jan 27, 2009
  • 700 Answers
The water resevour is frozen . take and heat up the tubing until the water flows thru.
Posted on Jan 21, 2009
  • Todd Born
    Todd Born Jan 21, 2009
    its easy access its at the bottom of the refrigerator section
  • Todd Born
    Todd Born Jan 23, 2009
    it should be in the refrigeator side towards the bottom back.
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
Water leaking
If there is water under your crisper drawers your drain line under your freezer panel is clogged up or frozen over.
Jul 28, 2012 | Amana ARB2257CSL Bottom Freezer...
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have an ARB2257CSL Amana bottom freezer refrigerator and the fridge portion just stopped cooling things down. The milk is warm but the freezer is working fine. We put the fridge all the way up and it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 09, 2010 | Amana ARB2257CSL Bottom Freezer...
My refrigerator starts to get warm and then my freezer back wall turns into a wall of frost. From reading other posts I figured out that I could unplug my refrigerator for a few days to let it thaw out....
Good day,
Your on the right track. The defrost system has failed. It is made up of 3 components. The main defrost heater, mounted to the bottom of the cooling coil behind the rear panel in the freezer compartment, the defrost thermostat which is a small round disk with 2 wires coming out of it located in the same area clipped to the top of the coil, and lastly, the timer which is located in the food compartment, on the roof behind and to the rear of the controls.
To test the timer, (there is a small hole to stick a screw driver into it) turn the shaft clockwise until the machine turns off. Wait 45 minutes. If the machine comes back on, the timer is O.K. Replace the defrost thermostat. If not replace the timer.
It is possible the main heater has failed, but it is a rare occurrence.
Mar 01, 2010 | Amana ARB2257CSL Bottom Freezer...
I have a amana bottom freezer refrigerator that is cooling the top section
i think you mean its not freezing at the top? if this is so, sounds like you have a gas leak, you cannot fix this yourself unfortunately you may require a technician to fix the leak and top up your gas.. make sure they fix the leak or this will happen again. hope i have helped
Nov 11, 2009 | Amana ARB2257CSL Bottom Freezer...
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
Freezer door light switch sticks, have to pull on switch nob.
sand it with 600 grit sand paper. and spray some lube W-D-40 on it.
Jul 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Amana ARB2257CSL Bottom Freezer Refrigerator Logo
121 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
