My Ideal Air 12,000 BTU portable AC is displaying an error code of P1 ...has been working normally but now no cold air..when unit is turned off ...and condensation drained it runs I with condenser on
    Problem Solver:
  • 5 Answers
They always produce water hence the word condencer ALWAYS DRAIN depending on usage
Posted on Jan 10, 2013
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: Error code A5 on Frigidaire
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Posted on Jun 05, 2009
  • 653 Answers
SOURCE: Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Posted on Jul 10, 2009
SOURCE: everstar portable ac unit displaying error message P1
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Why is my Kenmore 72012 blinking?
Does the display blink no matter what is displayed? If the display always blinks the same info, what might that be(i.e. error code)? If you are able to cycle through settings and the display changes while blinking, the problem is likely in the control circuitry. The controls have a built in delay to protect the system from abrupt changes. You'll notice this delay, and the blinking display, when you first turn these units on and when changing modes.
Jul 12, 2014 | Kenmore 72012 Portable Air Conditioner...
The red light is still on and the ac does not working what can i do?
Regarding the AC , it does not come out or the air is present but does not become cold? These are details you should post because experts need a clear picture of it before any solution.
now i am posting this here but i will ash you a further info anyways!thanks,
Cris,the best on FIXYA
Jun 29, 2014 | Danby 12,000 BTU 3-in-1 Portable Air...
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Ac keeps turning off after one minute running
the thermometer that controls it all might be in the wrong place maybe too close to the cold air with is telling the ac its already cold and shuts off
Mar 15, 2013 | Keystone 12,000 BTU 115V Through-the-Wall...
Why is Portable AC is leaking?
Condensate should be directed outside. The condensate collection device may be plugged, broken, missing or not draining (overflowing)
Sep 12, 2012 | De'Longhi Delongi PACA120E 12,000 BTU A...
Need my users manual
Here is a link to a 12,000 BTU, Danby Portable AC Unit. Since you failed to mention the model number of the unit you have, I can only guess that is the same as yours. In any event, all Danby Portable AC units work the same. You can download and print this manual for future reference.
http://www.danby.com/cms/uploads/products/en_manual/DPAC_12099_EFOM.pdf
I hope this helps you and thanks for choosing FixYa.
Jul 23, 2011 | Danby Portable Air Conditioner
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Jul 10, 2009 | Danby Portable Air Conditioner
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
