The fabric softener drawer does not empty after a washing cycle so how do I solve this
The fabric softener does not empty after the washing cycle. Does the drawer need cleaning or is something else preventing it dispensing after the final wash.
    Top Expert:
  • Washing Mach... Master
  • 42,927 Answers
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Posted on Jan 10, 2013
  • 24 Answers
SOURCE: Dispenser still full of water and fabric softener
My dispenser was always full at the end of the programme. I took the drawer out and pushed a drinking straw down the hole that takes the conditioner into the machine... this was bunged up with gunge... has been fine since.
To get rid of the residue and get your machine sparkling... 1/2 cup of Washing soda crystals on a 60 degree wash. Run machine with no washing and let it run the full cycle..
Add 1 desert spoonful of washing soda to every wash.. sprinkled in the gap in the door seal to keep the machine in tip top condition and smelling great.
You will find your conditioner smells amazing when you get rid of the gunk...
Posted on Aug 03, 2008
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
57 varieties
  • 1653 Answers
SOURCE: Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
SOURCE: WFLI2440 FRONT LOAD FABRIC SOFTENER NOT DISPENSING
Hello !
We also had the same problem a few months ago until i cleaned the little water holes that dispense the water with a steam cleaner (high pressure) it completely removed the blockage after i actually pushed the nozzle against the little square holes where the water come through. After that i ran the machine on a 90 degrees wash empty to get rid of all the gunk and ever since the problem does not seem to happen any more.
Posted on Jan 13, 2010
Bosch classixx 1200 fabric softener dispencer doesn't empty into machine just fills with water
Pull out dispenser drawer in the middle section for fabric softener lift up top plastic cover and flush out hole with water and this should solve the problem
Jun 08, 2017 | Bosch Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric softener drawer water residue after washer completed cycle
This is probably due to a build up of residue of softener. Remove the drawer, strip the bits off, and clean with a toothbrush. Then replace, and this should solve the problem.
Apr 11, 2015 | Zanussi ZWF1430W Front Load Washer
Fabric softener drains out, but pumps water back into dispenser after draining?
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
My washing machine fabric drawer is blocked have cleaned complete drawer but still fabric softner is in the drawer at the end of cycle .
Pull the little 'hat' off it's post in the fabric softener compartment. Clean off any softener residue and return.
Mar 17, 2010 | Hotpoint Washing Machines
The fabric softener container doesn't empty during the cycle of the washing machine. Adding water manually does empty it - so I guess there's a problem with the fossit. The machine opens from the top. The...
It is more than likely that the water inlet orifice is blocked.Get something to poke into the hole or holes in the top of the soap drawer compartment over the fabric conditioner compartment.
This should solve the problem.
Dec 11, 2009 | Washing Machines
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric softener stays in drawre
I had this same problem to
If you take out the drawer of the washing machine and look upwards there are 4 very very small holes get a pipe cleaner and giver them a jolly good clean.
This should then solve the problem
Jul 07, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
535 people viewed this question
Top Washing Machines Experts
