Question about Bruder MAN TGA Container Service Truck
Ffr00647-10 why showing on computer scerne
Ans my question
Checking power for fuel pump
Do you know what a fuel pump relay is ? You can check B+ Voltage an control at the relay > Find the relay in the under hood fuse box . Pull the relay out an look on the bottom , you should see four sets of numbers 30,87 an 85,86 ! 30 an 87 are the power side ! One of these will or should have B+ voltage , the other goes to the fuel pump . You could take a piece of wire an jump 30 an 87 , in the fuse box where the relay plug's into . The fuel pump should run ! The control side 85 an 86 , one will have B+ voltage an the other will be open circuit , unless you crank the engine ! The PCM supplies a ground when an input from the crank sensor is sensed. Videos on youtube on trouble shooting an testing fuel pump electrical circuits .
Sep 13, 2016 | 2001 Chrysler Voyager
Can ES5D000G4S01 Subcards Be Used on Both S5700EI and S5700SI Switches?
An ES5D000G4S01 subcard can only be used on an S5700EI, and an ES5D00G4SA01 subcard can only be used on an S5700SI. If an ES5D000G4S01 subcard is installed on an S5700SI or an ES5D00G4SA01 subcard is installed on an S5700EI, the subcard cannot register.
An ES5D000G4S01/ES5D00G4SA01 front subcard must be used with an ES5D00ETPB00 extended rear subcard; otherwise, only the first two interfaces on the ES5D000G4S01/ES5D00G4SA01 subcard can work.
Jun 13, 2016 | Computers & Internet
How to connect an lcd connector on an lcd for an asus u47?
Watch this YouTube video which explains how to replace the screen.
Oct 17, 2014 | ASUS Computers & Internet
WHAT TYPE OF OIL DO I PUT IN MY 1999 GMC SIERRA 6 LITER V8?
5w30 in cold months 10w30 in warm to hot months. High milage if its over 75,000 miles.
Apr 20, 2014 | GMC Cars & Trucks
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
Apr 21, 2013 | Computers & Internet
97 ford contour od light flashing an second gear slips an it wont go into od
Yes the converter and bands are toasted. You more than likely need a transmission.
Aug 18, 2017 | 1997 Ford Contour
Is it possible to connect an iPOD to the Sony Receiver STR-DE598?
go hood with it an take a pair of audio rca jacks cut one end take an old head phone wire cut the end about six inches splice them hook the pos to the pos of the rca an the neg to the neg tape each one so they dont touch each other an plug the rca side into the receiver plug ur ipod or phone in an turn it to the aux mode an bamm works on car an house stereo,,,,Thats what we do at 3am an thers no where to buy a wire,,,,,,B^D l^nDz....215.....*$*$
Nov 08, 2011 | Sony STR-DE598 Receiver
I need To reinstall the OS
Check if you can get in safemode n do a system restore
Else try backing up your files to another drive other than root drive (C drive by default) using a live Linux CD. Try "puppy Linux" tats 90Mb bootable disk, that can mount almost all drives (ntfs, fat32 etc)
Then do repair or reinstall if necessary using the windows disk.
Sep 08, 2009 | HP Mini 1035NR Notebook
Car stalls an shuts off an then needs to be jumped
i had a similar problem with my 98 eclipse...there is 3 relays on the firewall on the drver side,check those,i changed mine and hav'nt had a problem since...good luck.
Jun 01, 2009 | 1997 Mitsubishi Eclipse
Burns out foul pumps
thanks for getting back well about an hour an i have put 5 of them in an they run great for that hour cleaned tank an sending unit an all liens o an you no its a 7.3 liter deisel
Aug 30, 2008 | 1999 Ford F350 Regular Cab
Bruder MAN TGA  Container Service Truck Logo
44 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
