Question about HP Designjet T1100ps Printer
HP T1100 settings for custom paper size
I am unable to save the settings fo rcustom paper size using the HP T1100 plotter
  • 4 Answers
SOURCE: Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
  • 96 Answers
SOURCE: error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-167.
�� If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
Posted on Oct 01, 2009
SOURCE: Hp P4515n - Paper Handling for tray-2 only, gives
I just ran into this same issue with an HP LaserJet P4015n. Worked with HP and the resolution ended up being the following.
Hopefully this will work with the P4515n printer as well.
1. Open EWS page (printer page) in Internet Explorer.
2. Log into printer as administrator
2. Click on Settings tab, Configure device, System Setup
3. You will find Tray Behavior
4. Change tray 2 model to Standard Tray.
This should give you the standard options for the Tray 2 size or default to the size detected.
Posted on Jul 29, 2010
seeker5211
  • 1089 Answers
SOURCE: error 47:01 in hp plotter t1100
Star Wheel Motor has a problem.
01 code says "reseat/reconnect/clean and manually adjust" the motor.
The Star Wheel Motor is on the left side of the printer.
If you arn't trained on it, get someone who is, to service it.
Posted on Jan 24, 2011
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Error 47:01 for hp desighjet t1100 plotter
This error relates to the starwheel assembly and motor. Open the printer and make sure that there are no paper jams or anything blocking the star wheels (the little pointy wheels that guide the paper.
If nothing is visisble then service diagnostics are required. Not sure of your technical skill level, so post back if you are comfortable disassembling the unit, if not, contact HP to find a local Designjet technician.
May 20, 2011 | HP Designjet T1100ps Printer
I go under custom paper size, put in 5/5x8.5. It won't let me save what I input. So, I can't print my invites. My printer is a HP photosmart Premium C309
On the custom page box, you must first enter a unique name for the custom size that you want to set up. eg. Invites. Once you enter the name the "save" button will be highlighted. Save the name, then fill in the custom sizes and click OK.
Your new custom size will be under Properties/Features/Size/More
Aug 07, 2010 | Office Equipment & Supplies
I am faceing the problem hp dj t1100 inkjet printer. No connectivity avaiable.
For a single computer you can install a JetDirect card and assign an IP address. Then connect the computer to the plotter directly through the ethernet connection on the computer using a cross-over cable (standard ethernet cable will not work unless you use a hub). Another option is to simply use a USB cable connection. Drivers are available from HP.com, Support, Downloads.
Mar 02, 2010 | HP Designjet T1100 Photo Printer
Setting a custom paper size on a J6450 printer
Have you gone to page setup and set those sizes?
Feb 12, 2009 | HP Office Equipment & Supplies
Driver to HP1050C ...
Friend,
All drivers for the 1050-series printers can be found HERE:
Hope you sort it out.
If not, could another solution be to save the file as a .pdf and send it to your customer?
//Al
Jan 12, 2009 | HP DesignJet 1050c InkJet Printer
Can not set custom paper size in HP C7180
I had to seek Help several times, and then work through the steps a few times before I learned the overly complex HP method for setting custom sizes (I never thought I would have anything good to say about Dell printers, but it was MUCH easier to set custom sizes on my old Dell than on this HP C7180).
Anyway, it sounds as though you are nearly there. After you set the size and save the name, you must click OK, then click OK in the Document Properties window. Then close any open windows, like "Document Properties" or "Print Pictures", and start over from "Pictures" or whatever photo browser you are using. Chose an image and click "Print". Under Printer, chose "C7100 series", not "...series fax". Under Paper size chose "More". Your new custom size should now be the last size listed (although, it has shown up as the first size a couple of times, ...go figure). BTW, I am using Windows Vista.
Hope this helps.
Nov 23, 2008 | HP Photosmart C7180 All-In-One InkJet...
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
HP Designjet T1100ps Printer Logo
281 people viewed this question
Seeker5211
Seeker5211
