Question about LG Dh3120s Dvd 5.1 Channel 300W Home Cinema System Non Hdmi New For 2012
Change the region on DH3120s - LG Dh3120s Dvd 5.1 Channel 300W Home Cinema System Non Hdmi New For 2012
I own a 5-DVD Changer with a Home Theatre System. It is an LG Model # LH-E932TB. It was working great then all of a sudden it now says ''CHECK REGIONAL CODES''. Does anyone know what to do...
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
Jul 09, 2011 | LG Audio Players & Recorders
My pc dvd drive won't let me change region back
No its not a bug most DVD-ROM computer drives allow you 4 or 5 region changes first check your region code and number at DVD Region Info it will tell you region code Australia is 4 UK is 2 sand so one plus you region changes http://www.visualdomain.net/
I however do suggest removing your region code from your DVD-ROM using a region free firmwar or on your PC you can use http://www.dvdidle.com/dvd-region-free.htm it is however a bit pricey the region 0 firmware hack would be better.
Dec 01, 2009 | Computers & Internet
Changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
Oct 01, 2009 | Sony PlayStation® 3 (60 GB) Console
I need to change the region from 1 to 4
You have to go to the device manager of the operating system. List the hardware. Right click on the actual dvd drive and select the area that you want to change the region to. It will display the region.
Aug 10, 2009 | HP Pavilion dv5-1160us Notebook
Changing the DVD Region code
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
Jan 26, 2009 | Microsoft Windows XP Professional for PC
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Unlock dvd rom to region free
Download software like region free dvd player then check
Nov 21, 2008 | Computers & Internet
DVD Player region coding changes
You can only change the region code 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play and region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
Nov 17, 2008 | HP Pavilion dv9000z Notebook
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
LG Dh3120s Dvd 5.1 Channel 300W Home Cinema System Non Hdmi New For 2012 Logo
Computer Repairing
Computer Repairing
