Question about iRiver E100 Digital Media Player
I can get the time and date to stay
What do i do next?
  • 32 Answers
You have the time there to check when you have with you
Posted on Mar 04, 2009
When I turn on my c182 it says set time and date. when I do that next time I turn it on it says the same thing.
Usually when doing this you have to press 'Done' or something, not just go back to the menu. If you don't the date doesn't stick.
Dec 26, 2013 | Kodak Easyshare C182 12MP Digital Camera
My date is not getting set in bios
Change the CMOS battery.
If you had taken the time to post the computer manufacturer name, and model number; I would know what motherboard we're dealing with, and what type of CMOS battery it uses.
Generally the battery is a CR2032.
A type of watch battery.
Positive ( + ) side ALWAYS goes UP
Post back in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | Computers & Internet
Orange light stays on will not boot
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Dec 16, 2011 | Compaq Presario sr1303wm Computer - AMD...
A friend bought a Canon A480 on my recommendation but she can't get the date/time to stay. She has to reset it every time she uses the camera. The user guide says to replace the date/time battery but this...
If it's a new camera, and it is doing this, it is defective. Your friend might consider returning it for replacement. But before she does, one quick thing that she can check is to reseat the little clock battery that controls the date/time. The battery could well have gone bad. It's located in a little slot labeled CR1220 right next to the AA batteries in the battery compartment. Just use a fingernail to pry open this little compartment and remove and reinsert the little button battery. If that doesn't fix it, and if returning the camera is not an option, next consider purchasing a replacement CR1220 battery from your local drug store. It should only cost about $3.
Dec 28, 2010 | Canon PowerShot A480 Digital Camera
I have an old IBM THINKPAD R31 every time i turn it on it says to press F1 for ibm bios setup utility and F12 for ibm boot devices list so i pres one of the 2 and it does nothing it just stays the same...
This is caused by the small battery inside that keeps the time and date for the computer. If it is dead, you get the message you refer to. Sometimes they are easy to change, sometimes it is quite a hassle. If you go to setup, you can change the time and date for that session, but the next time it will be off again.
Aug 09, 2010 | IBM ThinkPad R31 2656 Notebook
The date and time will not stay after setting, is there a flash update?
This is a firmware glitch. If you disable the startup image, the date and time is not saved. To fix this issue, you must re-enable the startup image.
Turn on the camera and press Menu (M). Press the right side of the circular directional button to select the wrench. Press OK/Edit.
Next, navigate down to "Opening" and press OK/Edit. Select ON and press OK/Edit. Go back up to Date/Time and set the date.
Restart the camera to see if it works.
Jan 19, 2010 | Polaroid i1035 Digital Camera
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
Dec 14, 2008 | Computers & Internet
Camera will not keep date settings
I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
Dec 18, 2007 | Fuji FinePix E550 Digital Camera
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
Nov 22, 2007 | Rolex Day-Date President 118238 Wristwatch
iRiver E100  Digital Media Player Logo
18 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
