Question about Toshiba Dkt3220-sd Phones 3220 Ctx/dk Year Warranty Rz
Eminem ft 5o cent y adan my life - Toshiba Dkt3220-sd Phones 3220 Ctx/dk Year Warranty Rz
Tip
Battrey types and maintanance
<span> <p>Nickel-Cadmium</b></i><br />This type of battery must be fully discharged and then fully recharged every few weeks. If you don't do this, it will quickly lose battery life due to what is known as the 'memory effect'. The memory effect means if you don't follow the above procedure, your battery will only charge up to the percentage of the last charge.<br /> <p>For instance, if you discharge it to 30 per cent, it will only charge up the remaining 70 per cent. Do this repeatedly, and the 30 per cent will become unusable, giving you an effective 70 per cent charge even though the indicator will still show a 100 per cent charge each time you charge it.<br /> <p>Nickel Metal Hydride</b></i><br />Ni-MH batteries are similar to Ni-Cd batteries, although they are less susceptible to the memory effect. They also have a higher capacity.<br /> <p>Lithium Ion</i></b><br />These are the latest type of batteries, and have no real problems as far as the memory effect is concerned. The problem with these is that they lose their effectiveness if overcharged or left for a long time with a full charge. Always discharge these batteries if you're going to be storing them away.<br /> <br /></span>
on Apr 02, 2011 | Computers & Internet
My 2009 honda accord the wrench light came on.it says i still have 20 per cent oil life.how many miles can i run on 2o per cent
That is just a Gadget for oil & cabin filter, just forget it
or reset them to 100%
They are not tied to the vehicles systems
Change your oil every 4,000 miles tops & use
Full Syn 5W-20 as it calls for (Lincoln L/S)
The Honda you Scan for codes-you already know that
Feb 20, 2014 | 2005 Lincoln LS V6
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
Sep 12, 2013 | Audio Players & Recorders
Cost of running window a/c unit
the total power used is 750 watts so multiply that by the number of hours in use say 60 hours a week
so 60 X 750 = 42000 or 4.2 kw hours X 4 cents per kw/h =418 cents or $4.18 per week X 4 weeks =$16.72
if you are a college student talk with a maths teacher and see if what I an calculating is correct but there is no way that the ac unit will cost $150.00 a month to run
you have to be careful here as to charge you for an ac unit , it has to be on a separate meter and I suspect that he is trying to get you to subsidise his electricity account outside of the rent costs which include power for the stove and hot water
as an example we run a 2.7kw ac for 12 hours or longer and the total household bill at 21 cents / kw hour ( we live in a country where the power is a major component of the household budget) is around $360.00 per month so I think that by comparison he is trying to rip you off
seek legal advice on the subject and if the rent payment includes electricity usage then he will need a separate meter to charge for the ac unit
Jun 16, 2017 | Haier Heating & Cooling
AT WHAT PER CENT OF OIL LEFT SHOULD IT BE CHANGED?
i will assume your talking about your oil life indicator. the vehicle is designed to operate perfectly fine until you reach 0% granted you are using the correct oil.
May 26, 2012 | 2006 Buick Lucerne
I want to download my favorite songs
oh this is simple, just google search, Example for download of the song Stan by eminem, search "stan eminem mp3 download" and use the first link
alternatively, search in the site http://www.emp3world.com/ you will get most songs (English) If you want songs in other languages just use the Google search method
Jun 03, 2011 | Computers & Internet
I wan to download eminem video
via youtube or what server?
Oct 23, 2010 | Cycling
What do we came from: from Eva and Adan or from a monkey?
You were created in the image of God. He loves you. Try asking your creator who is the source of all truth. If you are truly sincere, you will receive an answer and that will be the beginning of your ecucation. God bless you.
Oct 03, 2010 | Custom Essay Cheat Guru
Lamp timer reset
You will need the remote that shipped with the television. Take it with you up to the television then press and hold the VOL- button on the TV and the SPLIT button on the remote. Message should say "lamp time was reset to 0". Make sure the remote is in TV mode and aimed at the TV's IR sensor.
Mar 04, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Toshiba Dkt3220-sd Phones 3220 Ctx/dk Year Warranty Rz Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
