York model # DJ048N10N1AAA2A gas won't ignight on heater unit
4 Suggested Answers
  • 51 Answers
SOURCE: Frontgate patio heater, serial number
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
Posted on Aug 21, 2011
boysor2933
  • 293 Answers
SOURCE: Williams gas wall unit won't burn.
It's a burner control problem. It maybe a defect on some protective devices (pressure switch, fire detector, etc.), a blown fuse, or a board defect (busted DC supply transformer, relays, or electronic devices).
Posted on Nov 13, 2012
jkmorris78
  • 5 Answers
SOURCE: I have a york diamond 80 heater. The part that
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
Posted on Dec 31, 2012
I have a Amana high eff 90 gas furnace, model#GUD090B35A,115v.60HZ,1PH, 13.2amax. For the past month, the heater's been intermittently cutting in & out. I can hear it kick in, then 3 sec later, kick...
furnace lights burners on then burners go outafter a few seconds, is that right? if thats correct , look for FLAME SENSOR it is a metal rod that flames will hit. about the thickness of a metal coat hanger. it is usually on other end as ignighter. it has 1 wire going to it. and held in by 1 screw. remove and sand off with sand paper. reinstall and turn on. it will be right were flames come out of burner.
Jan 22, 2014 | Heating & Cooling
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
Electric furnace won't light
tony this is a gas furnance do you seee a orange glow on the right hand side of unit
Jan 22, 2013 | Heating & Cooling
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
Pilot light shoots 10 in flame when ignighted
do you have natural gas or propane? and did you buy the right unit for the gas you have?
Nov 09, 2009 | Desa International CBP20T Wall Mounted...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
