Question about Akai PT4298HD Rear Projection Television
Picture shaped like hour glass
For some reason my tv picture is shaped like an hour glass i cant for the life of me figure out why it worked perfectly fine a few hours ago and i turned it on now and i get this http://www.flickr.com/photo_zoom.gne?id=700222415&size=o there arn't any options in the menu to change image demensions what is possibly wrong?
  • Trevor Pearson Jul 03, 2007
    I have no idea what an horizontal ouput transister is nor now how to look for ESR leaks, it did reset it self last night but now its back to the same thing
  • 41 Answers
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Posted on Jul 03, 2007
Part of the picture is off screen
Likely convergence failure. Hard repair. Needs TV shop to repair. Picture will be partially hour-glass shaped and the will be multi-colored picture parts.
Sep 03, 2014 | Panasonic Televison & Video
The picture on my Sony is shaped like an hour glass
There is an apparatus on the back of your picture tube called a yoke.This distributes your picture on your pic tube uniformly.If this or the circuits enabling it malfunction,then you will get distortion-namely an hour glass shape.Tv has to be trouble shooted.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Picture looks like hour glass.
You're probably talking about bad convergence. Probably Convergence power board. Only $20-$30 from encompassparts. com, if still available.
Apr 17, 2010 | Televison & Video
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
Hour Glass Picture
can you put it other way i did not understand what you want to say & que is not complete.
Sep 25, 2007 | GE 31GT660 TV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Tv picture shaped like hour glass
Big cap in the regulation ckt is bad. Depending on model could be various values, a shop could use their ESR meter to find and replace it.
Jul 03, 2007 | GE 31GT740 31" TV
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Zenith 46" with a "hour-glass" picture.
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem. If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage. The only way to have a board checked is to have an Authorized Service Center look at it. It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open. Call Zenith (LG) to see who they recommend.
Mar 25, 2007 | Zenith Z46Z83D 46" Rear Projection...
Picture is hourglassed shaped
your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Jan 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Akai PT4298HD Rear Projection Television Logo
73 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
