Question about Epson Stylus C70 InkJet Printer
Epson Stylus C70+ printing colour but not black
Hi
I have a Epson Stylus C70+. I have had the printer for 10 years but haven't used it until now. It has installed fine and works ok. The problem is that it won't print black ink. There definitely is ink in the black cartridge. I have ran the head cleaning utility many times but without success. Anyone have any ideas?
Thanks
  • 353 Answers
The usual reasons for ink failing to get to the paper are either a blocked/faulty print head, or an empty/faulty cartridge. If you have been using the printer regularly without a long disuse period, then suspect the cartridge first.
You say the cartridge definitely has ink. The ink level indicator may well be misleading you. The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the chip on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly, a cartridge that wasn't filled properly etc. Alternatively, the cartridge could be faulty and not delivering ink even though it contains some. The only simple way to check this is to replace the cartridge with a new one. You can re-use the original cartridge later if it turns out not to be the problem, but make sure you tape up the feed hole and breather channels to stop the internal sponge drying out.
If the cartridge is not the culprit, you can try soaking the print head to dispel blockages caused by dried ink in the nozzles. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the head clean process 2 or 3 times, but not more; leave for 24 hours for air bubbles to disperse then repeat. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
Posted on May 05, 2009
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
My Epson R265 prints all of the colours green
Sounds like colour contamination to me.
Check the carts are in the right slots.
then print until it clears the problem.
May 09, 2009 | Epson Stylus R265 InkJet Photo Printer
ESPON Stylus Photo R200 Ink Status Problem
The epson like many other brands actually uses a small amount of the coloured ink in order to give the black print a more polished look.
You must use your printers properties page to set printing mode to Greyscale if you don't want it to use the colours.
To do this go into your control panel, open the printers icon, and select your printer, right-click on it and select Properties from the grey menu.
You will have to look through the pages and find the setting or check box for Grayscale. When you find it, select it, then click ok at the bottom of the page. This will stop the printer from using coloured inks to tone the black print.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson c46 printing
you can if you tell your printer you are only useing back
Oct 15, 2008 | Epson Stylus C46 InkJet Printer
No colour on paper
check for printer settings maybe the default has been changed to grayscale or black and white chage it to color.
Jan 27, 2008 | Epson Stylus C86 InkJet Printer
Printer= Epson stylus Photo R200=will not print in black
The printer is designed so that you have to have ink in all the ink cartridges. They sell more ink this way. I have the same printer and investigated this a few years ago. there is no work around. Peter
Jan 10, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
Nov 04, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Epson stylus photo 895 error code
1Eb means no black ink, 1Ec means no colour. Change the cartridges and you should be good. you will need Epson cart numbers: T007 Black T008 Colour
Sep 28, 2007 | Epson Stylus Photo 895 InkJet Printer
Epson Stylus C70 InkJet Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
