Unlock honeywell t7351f2010 thermostat - Heating & Cooling
Visionpro problems
Remove the batteries and remove the R or RED wire from the thermostat's sub base R/ RED terminal for 1 hour, if this does not work, replace it.
1-800-honeywell
www.honeywell.com
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
How to unlock a honeywell TB7220 thermostat
Go to the following link and look at page 12 of the pdf file. It explains how to access the settings so you can unlock the thermostat. Hope this helps.
http://www.ntsupply.com/files/products/TB7220_data.pdf
Jun 11, 2010 | Honeywell Programmable Thermostat Heater
I can't unlock my honeywell digital thermostat
Switch of the power and then lift the front cover upwords and seeing your manual you can unlock with your pointing finger.
Jul 31, 2009 | Honeywell Electronic Programmable...
How to lock a Honeywell TB7220U Thermostat
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
Jul 02, 2009 | Honeywell Electronic Programmable...
Thermostat is in the locking position, need to unlock
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Mar 04, 2009 | Honeywell Electronic Programmable...
Locked themostat
go to this link, www.honeywell.com. In the search box, type in the model number.
Aug 05, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
