Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
I need the circuit Board for a G.E. Refrigerator Monogram model ZISS420DRISS
  • 52 Answers
Which board do you need? there is 2 the mother board or hm Board.
Posted on Jan 21, 2009
  • bappliance10 Jan 21, 2009
    Your model number is not complete you have a letter missing between the r and ss
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Ziss420driss ice maker
Hello there... what is the make and model of your ice machine?
Jun 24, 2014 | GE Monogram ZDI15C Automatic Icemaker
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
I have a GE Monogram Model # ZIBS2OPASS. it is a small refrigerator and Ice maker. The problem is there is no power to the refrigerator so it is not cooling. There is power to the ice maker (basicly...
Hi this sounds like you have a bad control board, there is actually 2 to this model and could be either one and are not very easy to tell which one, I would recommend calling GE for service.
Sean
Mar 28, 2011 | GE Monogram ZDI15C Automatic Icemaker
42" Built-in Monogram Refrigerator just lost power.
Check the Compressor starter. This is a black box on the top of the compressor. See if it is getting any power, also with a flash light you will be able to see if it is burnt it looks like a BIG fuse. If it is popped you will need to replace it then all will work ok after that
Jan 03, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jan 21, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
259 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
