Question about HP 49g+ Calculator
I change batteries and the sign "Low battery" remain there
I change the batteries HP49g+ all of them, including the back up but the sign "Low battery" always keep on. Every time I turn on the calculator the sign is there. I don't want to make a Hard reset since I would lose all the programs.
  • samurijder Feb 10, 2009
    Low battery (s) keeps appearing when powering on. Replacing the backup battery didn't solve this problem.
  • HP Master
  • 7,993 Answers
If you do not want to lose your programs, move them to an SD Card, and perform a reset. Maybe the problem will be solved.Then you can transfer the programs to theit directory.
Hope it helps.
Posted on Sep 09, 2009
Range finder low power problem?
back again on his word. The Wizard requires Dorothy and friends to bring back the broomstick for this Wicked Witch of free airline before he grants their wishes. When they bring him the broomstick, the Wizard realizes he can't actually keep his promise. Know your business and its capabilities. Don't promise items can't be delivered, and sure to provide on what exactly that has the ability to.
https://800support.net/yahoo-support/how-to-contact-yahoo/
Aug 22, 2016 | Optics
No low battery warning..
  1. Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
  2. On the Select a power plan page, next to the plan you want to change, click Change plan settings.
  3. On the Change settings for the plan page, click Change advanced power settings.
  4. On the Advanced settings tab, expand Battery, expand Low battery level, Reserve battery level, and Critical battery level. Change the percentage of battery remaining that you want for each level, and then click OK.
Oct 14, 2013 | Acer Computers & Internet
My Dell XPS M1530 replaceable battery showing warning sign on the battery icon.
Try to see if there is a BIOS update for your laptop. The last version is A12. That sometimes will fix the problem. If not then it is most likely that the internal charger is built into the motherboard of the laptop is starting to fail. You would have to replace that part or most likely the entire motherboard.
May 04, 2017 | Dell XPS M1530 Notebook
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
Why BIOS settings including DATE/TIME do not remain after shut down??
the time is keeping by battery cmos, when the battery clean out of so can no keep , you much change new battery cmos. How to change?
you see in your motherboard have the battery u take off and get new here
Jan 20, 2010 | Computers & Internet
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
The calculator, hp49g+, will not turn on by pressing the "ON".
If batteries are fresh use a paper clip and insert it in the hole (reset) to the left of the serial number. Press gently.
Hope it helps.
Oct 10, 2008 | HP 49g+ Calculator
TI 83 Plus Calculator
You can try to turn the contrast down by pressing 2nd and then hold "down" If the screen does not fix, put new batteries in (including the back up batteries). The problem will be resolved. Hope this helps...
Aug 18, 2007 | Texas Instruments TI-89 Calculator
HP 49g+ Calculator Logo
328 people viewed this question
Seeker5211
Seeker5211
