Question about John Deere Tractor Turbo Charger 6200 6200l 6300 6300l ()
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
SOURCE: i need to rebuild a hydraulic cylinder on a john
Posted on Apr 07, 2010
SOURCE: I have a 1982 John Deere 310A backhoe. The
try changing out the hydro filters
Posted on Feb 17, 2011
May 21, 2017 | John Deere Garden
Feb 18, 2017 | John Deere Garden
Sep 06, 2016 | John Deere Garden
Aug 24, 2014 | Garden
Oct 28, 2013 | John Deere Tractor Turbo Charger 6200...
Jul 03, 2017 | John Deere 6200 6300 6400 6500 7500 Water...
May 29, 2017 | John Deere Garden
May 09, 2010 | John Deere Muffler 1010 Diesel Tractors
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
