Question about Power Acoustik Performance Teknique ICBM-DTACH
How to reset the deck - Power Acoustik Performance Teknique ICBM-DTACH
Pioneer deh-4450bt how do I reset when no button also unit wont turn off using src button
Hi, the way you properly reset that deck is this. Get the removal tools, slide them in to release the deck. Once its out look in the back corner of the deck for a fuse. R -R the fuse you should hear it cycle, thats it.
Jul 11, 2016 | Pioneer Car Audio & Video
Treadmill will not come on
1) reset the c.breaker from your home or blown fuse and repair
2) test the power cord for open or break with DVOM OR VOM very important
3) reset the treadmill with the switch
4) open the treadmill and see the fuse blown and repair or c.breaker and reset.
5) LUBE the deck belt , this happen because the lack of maintenance produce enough friction between deck vs deck belt.
6) lube the rollers bearing too.
7) test the input voltage motor, if there are the motor need repair.
8) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Jul 11, 2012 | Proform 580 LT Treadmill
I have the kenwood 348u and when i pulled the deck out a speaker wir touched the deck it went into protect mode now it doesnt have any sound and says waiting
try pressing the reset switch if it has one. The reset switch should be a small pencil tip sized indentation on the face. It will not be marked. If you have no reset switch, you can try disconnecting power from the deck for a few minutes.
Oct 30, 2011 | Kenwood KDC348U
My kenwood stop and the word PROTECT is on , what shall I do? kenwood kdc-mp342u car cd player.
Try checking your speakers and speaker wires for shorts and/or grounds if you can. If they all check out good, try resetting your deck. The reset switch should be a small indentation about the size of a pencil tip on the face of the deck. If all that doesn't work, you may have a bad output ic inside of the deck.
Oct 13, 2011 | Kenwood Car Audio & Video
My deck DEH-P840MP will reset it self once in
because u r a **** a lick to much cocl sorry buy new radio ******
Jul 14, 2009 | Pioneer DEH-P840MP CD Player
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Deck Resetting
I KNOW THE SOLUTION EMAIL ME AT DJWOLFUK@HOTMAIL.CO.UK
Feb 27, 2008 | Stanton C.304
How do you reset this deck
There is a reset button on the left front of the deck>
Feb 16, 2008 | Kenwood KDC-MP2035 CD Player
JVC KD-AVX1 Sirius Just Quit
Hi guys i need help i bought a use KD-AVX1 and i don't know how to use it i need help how to get a manual for my radios appresiated your help.
Apr 29, 2007 | JVC KD-AVX1 Car DVD Player
Power Acoustik Performance Teknique ICBM-DTACH Logo
14 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
