Question about Panasonic PT-47WX49 47" Rear Projection Television
I need a sevice manual can anybody help?
The tv turns off about 3 seconds after i power on im going to fix this, and with the help i'v seen so far things are looking good
  • 944 Answers
I think you may have seen this site, but just to be sure; http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html It looks very useful for you. these guys have a service manual and supplement for sale; https://www.manualsparadise.com/ShowProductsForModel.do?model=M77759179 also I saw a blog saying that you can actually order these from panasonic direct - haven't tried it myself Hope this helps :)
Posted on Jul 03, 2007
SOURCE:
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
Sony bravia kdl-v40a12u wont turn on has power going to the board and fuse is ok please help
hi. im donald i seem to have the same problem with my tv, has anybody given you asolution, i desperately need one as well, so frustrating.
Sep 11, 2011 | Audio Players & Recorders
Westinghouse SK-32H540S 32 in. LCD TV It went off by itself and now will not came back on. The power light flashing I did unplug it for an hour and that did not help.
i have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Jan 02, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
I want to use it in my trailer using an adapter with my 12 volt system. Will this work and if so how much drain on the battery will a 10 second stir be?
Im assuming you are using a power inverter right? Before you do this see what the output power for the inverter is and see what is required on the majic bullet. For instance. My small inverter has a power output of 110v and i tried to charge my craftmans 19.2v battery. Well I didn't check that the charger required 120v of power and thus I fried up one of my batteries. As far as drain on your battery? a 10 second or 5 minute go will not do anything to it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 11, 2009 | As Seen On TV Magic Bullet Food Processor
Don't store tv setting LCD40F86BD
im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Jun 12, 2008 | Samsung LE40R74BDX 40 in. LCD Television
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
