Question about SanDisk Sansa c200 MP3 Player
My mp3 is not charging and it says connected but it still says battery low. what do i do. i need help now. please help.
  • 8,596 Answers
Here is the full barrage of methods you can use if that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
My sumsung YPK-3 mp3 player does not charge. When I connect to the PC the usual charging screen comes up saying it is connected and is charging. Even after over 5 hours, it did not charge at all and when...
The battery is at fault. The charging circuit is fine as it says CHARGING. As the battery is at fault you may like to as Samsung to replace it if the device is still under warranty. Else replace the battery.
Jul 05, 2011 | Samsung YP-K3 MP3 Player
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
Low battery please charge when connected to pc...not charging
try charging into a different usb port.... like on the back of a dvd player or a tv or a VCR or anywhere else you can find a usb port
Nov 22, 2009 | Sony Walkman NWZ-B105F MP3 Player
Mine is a mp3 player that I have had for a while and it doesn't
i have a keo mp3 2gb player that decided to not turn on. I thought the battery was low but after charging it still would not turn on unless it was connected to the computer. Can you help?
Aug 31, 2009 | Keo 13464CU (1GB) Digital Media Player
Charging battery
Make sure the hold/lock switch is not engaged - then recharge
May 27, 2008 | Samsung YP-U3 MP3 Player
Battery can't charge
You all need to get the latest firmware upgrade from Sansa's website.
Apr 13, 2008 | SanDisk Sansa Clip MP3 Player
All it says is low battery and charging
The battery life is short - you must recharge every day
Mar 28, 2008 | RCA OPAL M4001 MP3 Player
All it says is charging and low battery charging
Must recharge every day by replugging into your computer
Sansa e250 2Gb - No Charge - My PC no recognize my mp3
if you plug it in to the computer mabe the drive cant charge it in some computers some drives dont charge the mp3s it happened to me but try to connect it to different arias and if that doesnt work buy the wall charger hope it helps.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
Froze/no charge
It has a very low batteyr voltage therefor your computer cant charge it. Buy a wall charger but you may have to put it on disk mode.
Jan 11, 2007 | Apple iPod mini 2nd generation MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
