Question about Maytag 26 cu. ft. Wide-By-Side Refrigerator - 36" - Stainless Steel
MY Maytag Wide by Side freezes in the produce drawers.
I have replaced the refrigerater motor in the freezer a year ago when the refrigerater wasn't cooling properly.
When I set the refrigerater warmer it's been gettin cooler instead.
I'm very frustrated with this product!!
  • 1,998 Answers
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Posted on Dec 15, 2011
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Wall between fridge and freezer is very hot
I understand you are a little irritable about your Maytag. If you would like the service manual or one on one help free free to let me know. Your refrigerator is a complex refrigerator. But quality is Maytag. They are the only company that I know that will go out of the way to insure their customer is satisfied. If you would like the service manual or personal assistance, please let me know, Sea Breeze
Jul 11, 2009 | Maytag MZD2766GES Side by Side...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Maytag Wide by Side (5 years old) Freezing Refrigerator & Freezer
There is 2 things you can replaced to rectify this problem .
1 is the defrost timer and the next is the thermostat.
On the thermostat is a metal rod that is connected to a vent so when you adjust it it open or closes the vent .Just make sure that is not loose because if it's loose even though you turn thermostat down the vent would be wide open allowing freezing air to get into refrigerator.
Jun 03, 2017 | Maytag MZD2752G Side by Side Refrigerator
Refrigerator is freezing on the produce side
if you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Feb 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag  26 cu. ft. Wide-By-Side Refrigerator - 36" - Stainless Steel Logo
141 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
