Question about Electronics - Others
Planar keep blowing fues when i turn it on - Electronics - Others
4 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: why do my fues keep blowing on my daewoo
First I suggest confirm what fuse blowing there and waht circuit and edevices are controled, check some wire broken or bad ground in the line and switch (if have one there).
Keep us updated.
Posted on Dec 06, 2011
  • 141 Answers
SOURCE: glow plug fues blowes
the glow plugs have a rail/wire that joins /links all of them that rail receives 12volts across it ,check that it is not touching against any metal earth surface ,if it seems to be fine disconnect the power wire to the rail and insulate wire .Then refit fuse and turn on key ,if the fuse blows you know that there is a short in the wiring going to the glow plugs ,if the fuse does not blow it is highly likely that one of the glow plugs has shorted and needs replacing
Posted on Jan 15, 2014
nobody322
  • 20706 Answers
SOURCE: My hilux won't start keeps blowing the ignition fuse when turning the key on
that is a dead short, the fuse saved you the ensuing fire.
there are 2 fuses or more... with that name..
old cars love to short things, no lie.
the fsm is the best thing to have, and alldata.com , 2nd.
the older that car the more true that is... and your car is 10x that.
a 1991
is the fuse in the cab BOX? NOT ENGINE BAY?
THE CAB FUSE , HAS these (USA cars, other are DIFFERENT)
no country stated (sigh)
ignition sw AM1
ignition sw AM2
ignitor 1
ignition coil (1 for 4cy, and 1 for v6 engine, unsaid)
on one car there is a IGN fuse 7.5 amps
and runs the ECU and main relay.
there are 3 engines, and drawing for all 3.
get the fsm and use that or login to alldata.com and hope
it covers your engine. (unstated)
22r,3vz,3F
Posted on Feb 12, 2014
Glow plug fues blowes
Jan 15, 2014 | Cars & Trucks
Every time I turn on the right turn signal the Fues blows. What to do? It only happens on the right turn. I keep replacing fusses , what to do?
replace the right turn signal bulbs... one of them is shorted out (filiment broke and is grounding to the body of the bulb)
Mar 23, 2013 | Cars & Trucks
I'm fues to my fan keeps going out on my 2006 P.T
More than likely you have an internal fault either in the fan itself or the thermostat that activates it.
For a fuse to blow it has to have a lot higher than normal current draw through it, which is normally refered to as a short. If the fuse blows almost immediately then I would suggest you unplug the fan, and see if the fuse blows with just the thermostat in the circuit. If it blows - replace the thermostat control. If it doesn't blow, plug in the fan and watch it. If it trys to start and then blows the fuse, replace the fan motor.
Jun 30, 2011 | 2006 Chrysler PT Cruiser
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
Blows the fues for the head lights
There must be a short to ground in the wiring to the lights somewhere. When you say turn on the headlight, aren't the lights on anyway as soon as you turn the switch to start the bike? They should be, that's standard.
May 11, 2010 | 2003 Harley Davidson FLSTC Heritage...
Every time i turn the ignition on,, a 20amp fues blow out ..the car is not starting..it will turn over but not start... the fues is in the power distibutor box only
what is that fuse for? If it keeps blowing then it is an indication of a short cicuit in the part/cable/wire for the unit the fuse protects.
Oct 03, 2009 | 1997 Ford Thunderbird LX
Why do my fues keep blowing on my daewoo
Keep us updated.
Mar 27, 2009 | 2001 Daewoo Leganza
Electronics - Others Logo
268 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
