Question about GE WBVH6240F Front Load Washer
Are you supposed to see the water level?
I just got my new front GE front loader - maybe it is no problem - but it seam strange that I see no water level at all during the wash. The water stops and runs 3/4 times and that is it. Can it really be right that it requires not more water is needed. I wanted to see if that is how it is supposed to be before I call the service.
  • marionthacke Jan 21, 2009
    Thank you - I understand that - but it still seems very little - even with that in mind. There is maybe an inch of water visible inside the drum. Being efficient is one thing - hardly getting the close wet is another. Does that sound right?
  • 3 Answers
It's very difficult to see the water level with the GE front loaders, and your estimate that there seems to be an inch of water is about right. Let the washer run until it stops adding water to the cycle (about 5 minutes) and then hit pause. Open the door and I'm sure you will find the clothes are sopping wet! If they are not then you definitely need to call for service.
Posted on Mar 15, 2010
    Genius:
  • 2,920 Answers
They dont take alot of water..thats one of the good things about the new machines like that. they use only what they need to do the laundry and thats it.thats why they call them so efficient
Posted on Jan 21, 2009
  • Ronnie Houston Jan 21, 2009
    how many times does the water run when you wash a load? 3 or 4 times? it should be doing whats its supposed to do conserve water...call the service department and ask them about it im almost sure they will say the same thing
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Is it getting enough water?
For front loaders, they usually have the level underneath the door, they use small amounts of water, but they spin so all the clothes do get
soaked with water.
Feb 05, 2010 | Samsung WF317AAG Front Load Washer / Dryer
Outside seams to be level but tub tilts during
Front loader?..Could be broken drum spring up top..
Oct 03, 2009 | Washing Machines
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
I have a GCVH6260FWW GE Front Loader. It will not
Yes you should see it - and call an electrician they can legally disconnect the "water saver" or adjust it safely
May 19, 2009 | GE WSXH208A Front Load Washer
Wont drain
you will have to take the front cover off. you will see a clip on the top right and left side at the seam at the top of the front cover. you can tale a screw driver or putty knive and push down on the clips and the front will pull off toward you. unplug the machine. you will see the drain pump at the front bottom right, the pump may be hung up. try turning the fan on the pump to free it up. if this does not work change pump. if water is in machine you will need to pinch off hose comming from tub if you change the pump
Apr 07, 2009 | GE WBSR3140DW Top Load Washer
GE Front Loader Won't complete cycle
My GE Front Loader is 18M old and it has been progressively getting worse, not spinning the water out......I should have known the Pump had a cleanable strainer as Solution #1 says. Pulled a fist size chunk of wet lint, coins, a necklace and wrappers from the Strainer, not to mention about 2 Gal of dingy, soapy water. Tried a Drain/Spin and after a couple of minutes, went to High Speed Spin for the 1st time in about 3 months. Obviously there is a Water Sensor on the Drain Line somewhere that if the Drain Line still has water in it, it does not allow washer to go into Med/High Spin Mode.
Jan 14, 2009 | GE WSXH208A Front Load Washer
Water wont drain /wont spin out
  • assuming it is a top loader
  • it sounds like something is stuck in the water pump.
  •  if the water does not drain then it will never spin.
  •  take off the front panel (with a butter knife, push in the two metal clips in the front seam between the top panel and the front panel. this will release the front panel from the machine.
  • the water pump is located on the right side in the front.
  • before removing the hoses attached to the water pump get as much water out of the machine as possible so it does not spill on the floor.
  •  then take off the hoses and check inside the pump thoroughly; even a string might cause the pump to get stuck.
  • let me know if you need more help
Mike
Jul 02, 2008 | GE Washing Machines
GE WBVH6240F Front Load Washer Logo
74 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
