Question about Philips 50P8341 50" Rear Projection Television
On-and-off button I can not turn on the t.v. with the on & off button,in order to turn it off I have to unplug it.
  • jose roldan Jul 03, 2007
    I can turn it on with the source select button,
    but not with power button-then in order to turn
    Problem Solver:
  • 7 Answers
ONLY RENPLECE PART # PH3912725871 IS SMALL BOARD GREEN 2 INC BY 4 INCH IS HAVE ONE FLAT CABLE COLOR WHITE IS INSERT IN BOARD LEF SIDE IF YOU SEE IN BACK SIDE IS PCB BOARD ALOT PROBLEM IS BOARD IS OVER HEAT
Posted on Sep 28, 2007
    Habit-Forming:
  • 45 Answers
The problem is due to the push button switch some small dust may be s trucking inside the switch and if u can check the switch u can make it work and there is no problem in making the set of by pulling the power supply cable
Posted on Jul 03, 2007
  • 398 Answers
That actually doesnt make much sense, as you say you cannot turn the TV on but the only way to turn it off is to unplug it, which implies that you can turn the set on. Do you mean you can turn it on with the remote but not the power button on the set, or do you mean that the set is always on unless unplugged?
  • Mike Longo
    Mike Longo Jul 03, 2007
    This sounds like the pushbutton itself has stopped working or cracked loose from the board. Philips sets usually turn on with the pressing of any front button, but if the power button is unresponsive while the other buttons work, then you need to have the pushbutton fixed or just use a Philips remote or universal remote set up for Philips to turn the set on and off.
SOURCE:
Dishwasher reset button
Hi friend, I appreciate your post!
I understand you are trying to locate a reset button on your dishwasher FDB1502RGC0. Generally dishwashers do not have a reset button on them but in order to reset your appliance as a whole. You would disconnect power to it by unplugging it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this helps. -Matt
Jul 23, 2014 | Frigidaire Dishwashers
I pushed a button and lost all sound, what should i do? is there a reset button to get going again?
The "MUTE" function on your remote control has been activated.To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office.
Dec 16, 2010 | Yamaha HTR-5930 Receiver
The "cancel" button for the upper section of my maytag gemini gas range no longer works. I used it yesterday and in order to get the oven to turn off, I had to unplug the range from the wall. Help!
Mine was doing the same thing. It was a stuck button under the touch membrane. If you are slightly mechanical you can fix it yourself, by first unpluging the oven from electrical power. Remove the upper panel, by taking 2 screws in back off. Also 2 screws on bottom. You can now tilt the upper control panel down to get at the controller itself. I removed it and unstuck the button. Works fine now.
Aug 09, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
Menu screen won't come up on screen
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding
down the ENTER button on the projector and press the MENU button for more than 2 seconds
Mar 27, 2009 | Panasonic PT-LB30U Multimedia Projector
HOW DO I REBOOT MY NETGEAR ROUTER IT IS A DG834G
It may seem dumb but why don't you unplug the power cord ?
Nov 07, 2008 | Computers & Internet
Printer won't turn on.
Try to unplug the power cable for about 2 minutes then plug it back in. Check if you can turn it on now. Double check the power plugs. Try to plug on a different power outlet.
Oct 13, 2008 | Dell 922 All-In-One InkJet Printer
Alarm from hell
I believe you can turn Nap off by holding the Nap button for several seconds.
Feb 25, 2008 | RCA RP5430 Clock Radio
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
