Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Need power cord SimpleTech 96200-41001-103 - SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
I have a simpletech 1 TB, and I lost my power cord 120-12 volts. Where can I buy one ?
I don't know your model number, but Amazon sells them, just check to make sure you have the right model number. Cost around $13
Amazon com Power Ac Dc adapter for SIMPLETECH SIMPLE DRIVE SimpleTech...
Nov 15, 2016 | SimpleTech Computers & Internet
Where can I find a power cord for simpletech
Hi, I think I found one for you 5V AC DC power adapter for SIMPLETECH 96200 41001 075 250GB USB hard... . If it is correct, it is OK to just find ANY power cord with Output Voltage: 5 Volts DC and Amperage: 1 Amps. It just need to fit in.
Sep 21, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
Lost power cord
I believe that you would be ok. Voltage has to be "Spot on." Amperage, however, needs to "meet or exceed." Think of Voltage as pushing something into something. Think of Amperage as pulling something out of something. It won't draw more amps than it needs, even if they are available. Allow me to thank you for including the powerpayless website as until your post I didn't know what voltage I was looking for. Exactly the same thing happened to me with my SimpleTech 1TB. Perhaps we both solved eachother's problems. PS: I'm going to check with Radio Shack for a 12v adaptor with at least 3.5 Amp capacity. They might can beat the $30.00 which is what the above mentioned place gets including shipping.
May 16, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Is it okay to use a 14-17 volt power cord for a Simpletech External Hard Drive?
The SimpleDrive requires a 12V/2A tip positive power supply. A 14-17V supply might work, but you run the risk of damaging your drive.
Mar 31, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
The power adapter does not work
open plastic case and pull out the sata hdd and put it in a comp with sata support
Jul 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 3.5inch 250 gb wont start up.
Contact simpletech about a product replacement if you believe that the item is defective. I had the same problem and they had got me a new one FREE of charge.
Jan 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
88 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
