Question about LG ELECTRONICS Remote Control AKB72976005 p/n:AKB72976005
What is the code for baja remote control fro 42ld620
La tv no tiene audio
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 14, 2014 | LG Used Original 32LX4DC Remote Control
How do I change the input so I can use the rca jacks in from the tv with the remote I have a salvania .
You are asking about the input selection of the tV, by using a RCA universal remote I assumes and posts this solution. All setup codes fro a tV with remote control might not work with all functions as it meant to be. Try an other setup code fro your TV with your remote. There is no other way than this. Universal remote codes for Sylvania TV are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Jul 04, 2012 | RCA Universal Remote Control
Code fro remote ONEFORALL remote
toooooooooooooooooooooooooo bad ****** jk 94201 there u go
Jul 08, 2010 | One For All URC-4021 Remote Control
Looking for rmote code for one fro all remot
Basically, you have to press the device-type button (like VCR, TV, or whatever), then hold the SET button until the light blinks twice. Then release the SET button and enter the 4-digit code for your device, and the light should again blink twice. Try the remote. If it still doesn't work, and there are several different codes, you repeat this process with a different code until you find a code that works.
just in case someone needs it also....here is the manual and codes to download.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc4605access4&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4605-manual.zip
Jun 20, 2010 | One For All URC-4605 Remote Control
Neen code fro remote rca to tv magnavox
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
check it out
Feb 08, 2010 | RCA Universal Remote Control
Codes fro emmerson jumbo universal remote
these are the codes...one should work....004...048...049...080...107...162....169...180
Mar 09, 2009 | Directed 434MHZ Remote Control
I need the code fro a new sky box hd
To find the codes for the sky boxes you will need to look at the user guide/manual that came with the remote control. Go to Sky's website for the remote codes. select version 8 for all new Sky + HD remotes
Mar 01, 2009 | One For All URC-3445 Remote Control
LG ELECTRONICS Remote Control AKB72976005 p/n:AKB72976005 Logo
37 people viewed this question
Computer Repairing
Computer Repairing
