Pump won't shut off
We have a 1/3 HP jacuzzi pump model # 3C HPS 1 which we are trying to use for a regular water pump to feed a household plumbing system. The pump turns on, only builds up to 32 lbs pressure but then keeps running, won't shut off. Any advise? Joy for Alan
  • albert getty
    albert getty May 11, 2010
    do you have a thermastat hooked up to it?
You need a new impeller kit. Does any one know where to find one?
Posted on Feb 24, 2009
Grunfos ch2-50
Can you describe the pump you have? Is it used for household water or a sprinkler system? Typically a household pump will have a storage tank and a pressure switch. 90% of the problems with a pump not turning off is due to the pressure switch.
Oct 13, 2013 | Grundfos Plumbing
I have a jacuzzi amiga N890 that when you turn the unit on it just hmmms. It is getting power but does nothing else accept hmmm.
If you turn the Jacuzzi pump on and it just hums and no water flows through the jets then you have a bad pump.
You will need to get the brand name of the pump and the model number before you can begin your search to find the proper replacement.
Bath Pumps each have their own size. You will want to find the exact brand so you do not have to change any of the plumbing.
US Parts Center
Aug 20, 2013 | Jacuzzi Amiga Whirlpool JAC-N890...
Jacuzzi hot tub pump. Put new pump and motor in water wont circulate but can here pump running.
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Nov 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
Most likely the impeller is clogged, or there is a blockage on suction side of pump/plumbing. Is the basket clean? You may also have an air leak. If the pipe coming into the pump, or the pump lid not sealed, or if a leak at a union, or valve coming into the pump is allowing air in, then the pump may not prime or move much water
Sep 10, 2010 | Jacuzzi Impeller, L - 3/4 H.P
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Jun 08, 2009 | Plumbing
Some of jet points inside jacuzzi are not mixing air with water
the jet are pushed by the impeller (it's like a fan blade) run by a moter water is pushed through the plumbing and out the jet head . when you open an air valve air is mixed in .
Feb 03, 2009 | Pool & Spa
Smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
414 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
