Question about InFocus X2 Projector
Black line on left side of projector
Projector shows black line on left side
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
We have a black line on the left site
the light tunnel needs to be adjusted or replaced if it collasped.
May 19, 2010 | InFocus ScreenPlay 4800 Multimedia...
The image from my cp x251 is uneven the top and right side are angled but the bottom and left side are straight and perfect on the screen.
this is a common problem with projection systems this is the reason that most screens are lined with black felt its non-reflective and works great to hide uneven edges also try balancing out the difference with the keystone adjustment
HitachiTech
Feb 08, 2010 | Hitachi CP-X251 LCD Projector
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
Vertical line
Hi Abouttime
This is unfortunately a sign of Mainbaord damage to any make of Projector.
But do give this a go , you've got nothing to lose.
Try using a different signal cable and then pressing Auto on either the remote of the Projector or the Projector it self once the line appears.
Thanks for using Fixya !
May 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
No color
Color wheel disc is broken and not repairable, problem is unless you know someone that can get the part you have to take your projector to an authorised service centre.
Dec 11, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus X2 Projector Logo
23 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
