Question about HP Mini 2140 Notebook
It is not supporting modem when i plug modem it is not even starting so how can i proceed so that the problem can be solved
  • HP Master
  • 2,385 Answers
You need proper drivers of device you intends to use
Posted on Jan 11, 2013
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
Can't connect to my wgr614v9 router
  1. Turn off the router by unplugging it.
  2. Turn off the DSL or cable modem for three minutes.
  3. Turn off all computers attached to your network.
  4. Turn on the modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step.
  5. Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
  6. Restart your computer.
Aug 11, 2011 | NetGear WGR614 Wireless Router
My router has been working fine for the past 5 months...Just recently, Every 3-4 hours it says that the internet connection is not available. I am still connected to the router, but without internet...
This is because your linksys router is dropping the connection with your ISP Modem...
It can be even an issue of modem...
To isolate the issue, what you can do is... You can connect your computer directly to the Modem and you can check for any intermittant connectivity...
if you dont have any problem with your modem, then definitely its gonna be the problem with your Linksys Router...
Doing a reset for the router and reconfiguring will resolve the issue in most of the cases...
If in case if it doesnt works, then you can do a firmware update for the router (that would be found in linksys router support website)...
Even then if it is dropping the connection then definitely it is a faulty router...You can ask for a replacement if the product is still under hardware & software warranty...
Dec 09, 2010 | Linksys WRT160N Wireless Router
I don't have driver usb hfs modem, how toget the driver ????
1. Where can I get drivers for my Rockwell/Conexant HCF or HSF modem for Windows XP, or I am having difficulty installing my modem in Windows XP?
Conexant has worked with Microsoft to ensure that many PCI modems are supported using a generic data/fax driver that is available on the XP distribution CD, therefore in the majority of cases your modem should automatically be detected and the generic driver correctly installed. Run the List Modem application (listmodem_app.zip) found on the Modem Driver Assistance page to find out if your modem is supported in the inbuild driver on WinXP. If the answer to "WinXp Inbuild Support" is yes, then your modem will work after upgrading to WinXP even when you run the compatibility test before upgrading and you get a warning. However the XP distribution CD does not have drivers for Conexant USB modems or modems that interface to the PC using the AC-Link bus. The AC-Link bus is primarily used in notebook PC's and some desktop PC's. In these cases it is necessary to download the correct driver from the manufacturer before upgrading to XP. If you get the message shown below and you have a notebook PC use the links below to obtain XP drivers.
Example XP Error Message: xperror.gifIf you do not have one of these PC's it means that the current driver that you are using in your previous operating system is not compatible with Windows XP, however if you have a PCI modem it is very likely that your modem will be supported by the driver available on the distribution CD and will work when you upgrade to Windows XP, and you should proceed with the upgrade. Links to OEM Drivers: carrot.gifSony VAIO Systems
carrot.gifGateway Systems
carrot.gifHP
carrot.gifDell
carrot.gifToshiba
carrot.gifLegend
carrot.gifAcer
carrot.gifNEC
carrot.gifFujitsu
carrot.gifTwinHead
carrot.gifMaxData
Jul 27, 2009 | Computers & Internet
To connect internet via bluetooth
thank you for contacting fxya,
you may use your modem wire and plug in to your laptop.now proceed the connection wish you a good day
Mar 26, 2009 | Computers & Internet
Can't fax - modems not being detected
ok, a modem on COM8 ? Normally modems are on COM1, COM3. You need to fix that problem first. Most softwares are not setup to scan that high for the modem. (ps: COM2, COM4 are usually for other devices - in the old days, mice were on COM2). Follow instructions:
START
CONTROL PANEL
PHONE/MODEMS
Click over to MODEMS
Click on Proper MODEM
PROPERTIES
ADVANCED
ADVANCED MODEM SETTINGS
Change COM8 port to COM3
click OK, probably going to have to restart computer.
Let's see if this actually solves the issue. if it did not and you need more help, contact me through this site and we will proceed forward.
Jan 15, 2009 | Toshiba Satellite M30-S350 Notebook
D-Link Dir 450 configuration problem
It seems like the routers firmware might be corrupted what you can do to solve these problem is basically upload the same firmware and check to see if solves problem.If not you might want to contact Dlink for further support even possibly a replacement if hardware is bad.
Sep 03, 2008 | D-Link DIR-450 Router (DIR450)
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No disc
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 06, 2008 | NetGear WGT624 Wireless Router
No Dial Tone on phones or modem
possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
Jan 30, 2008 | HP Compaq Presario Media Center SR1750NX...
HP Mini 2140 Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
