Question about NetGear DG834G Router
Problem connecting wirelessly using netgear router MR814v2
I am using the MR814v2 router. I have my main computer online. However, when I try to connect my laptop wirelessly, it does not connect. Its a new laptop and was catching signals for neighbouring networks and connecting sporadically to one of the unsecure ones.
I have set up a WEP key and used the 'AUTOMATIC' setting for the authentication and 64 bit for data encryption. It asked for a WEP key which I put in and then it generated 4 'keys'.
Now in the laptop, it shows my network in the drop down list, but says 'connection to WLAN failed'. I tried to edit it. Initially it wouldn't let me saying that the network was secure and it asked for a 'Network key'. At first I wasnt sure what to put in. THen I set up the above mentioned WEP key and the 4 keys. I used the first key as the ' for this. After clicking 'ok' the window just closed up. So I assumed that I was 'in' :) But it is still not connecting and I have no more light bulbs going on.
I have not set up any TCP/IP settings etc. The laptop is obtaining al that automatically for the WLAN.
All tips and help is most welcome!
Thankyou!
AZL
  • 55 Answers
Hi, you should consider changing your security to WPA-PSK or WPA2-PSK encryption instead of WEP as WEP can be cracked in a matter of minutes, even 128bit keys can be cracked easily. Plus there's no confusion over the four WEP keys generated.
With WPA you choose the key so it can be a word instead of random key, making it easier to remember. Just make sure its not a simple word that can be guessed, and use random numbers or characters so something like 64ranDomWordz92. Its case sensitive too so chucking in capitals makes it even harder to guess. Don't forget to write it down in case you forget it, make sure you write it correctly.
Now you know which key your using, go to manage wireless networks on your laptop and delete any profile you have for your network. Now when you try to connect, it will ask for your WPA / WPA2 passkey, just type it in and hit enter, you should now be connected.
Let me know if you need help with any of the above.
Posted on Jan 28, 2009
Unable to connect to netgear router
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Oct 09, 2010 | NetGear WGR614 Wireless Router
How do i get a pin number number from my router netgear wireless router mr814v2
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 17, 2010 | NetGear DG834G Router
I am trying to get my netgear mr814v2 to connect to the internet via hard wire to comcast with no luck. the connection is good when i go direct from teh computer
If you connect the computer to the modem it works, that means the modem is working.
Now connect the modem and the computer to the router and open the router set up page.
Clone the MAC address of the computer on the router and power cycle the network.
That will work.
Click here
for step by step instructions
Dec 03, 2009 | NetGear MR814 Wireless Router
I can not access my wireless internet network with my new computer. I have a netgear wireless router model MR814v2. I can get onto the internet when directly connected to my modem. However, when I try to...
Hook directly to the router hard wire. Go to configuration page for router and look at wireless security settings. it will show you Wep or some other encryption technique. It will also give you a place to view or change your wireless key. Once you do that write the key down and then connect wirelessly.
Nov 08, 2009 | NetGear MR814 Wireless Router
Wireless connection problem with the MR814v2
Try accessing the router by using the webpage address: ie linksys is: 192.168.1.1
and disable the security settings and save the setting and then try it on the other computers. If that doesn't work then see if there is a reset button on the back of the router. Push it in for a few seconds and then search for the wireless network which should be the routers name with a strong signal. If it still doesn't work then maybe the wireless portion of the router is going bad.
Hope this helps
Jul 08, 2009 | NetGear MR814 Wireless Router
Unable to connect to internet
just try to connect directly from modem ..... if your able to connect to internet just download the firmfare update from the site given below
http://kbserver.netgear.com/products_automatic/MR814v2.asp
Jun 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless connection
Check out the IP address is provided Dynamically correctly or not. If it is correct the open
http://10.0.0.1
Go to Status - set ip Dynamically - save.
Now, check the website opening.........
Mar 01, 2008 | NetGear MR814 Wireless Router
Netgear Wireless router MR814v2
the problem is that the router is not issuing the DHCP address, put in a hard-coded address such as 192.168.0.5/255.255.255.0 with a gateway of 192.168.0.1 and then manually add the DNS server address of the IPS as well and it will kick into life
Dec 15, 2007 | NetGear MR814 Wireless Router
NetGear DG834G Router Logo
933 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
