Question about Technics SA-TX30 Receiver
Sound cutting out - Technics SA-TX30 Receiver
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
Jan 03, 2012 | Mackie SRM-450 System
Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
Apr 12, 2010 | Philips Televison & Video
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
Oct 31, 2009 | Car Audio & Video
The sound suddenly cut out for my Bose 321 GSX system
I now have this same problem. Would like to know if there is a fix or if my system is just failing for good
Apr 09, 2009 | Bose 3 2 1 GSX System
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Amp gain problems!!!
is more than likely a loose connection
Jan 18, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
My Hitachi TV model # 57f710s doesn't have picture or sound.
It very well could be the flyback unit around 70.00 for part!
Dec 07, 2008 | Televison & Video
37 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
