Registration code for incredimail 2.0 - Computers & Internet
Incredimail wont log on to my hotmail address
you can go to website www.geekstechs.net for incredimail tech support
Mar 09, 2014 | Computers & Internet
How to i get incredimail on my Amazon kindle fire hd
John, I had the same question and I'd just gotten an email from them about an app for other types of tablets and phones. Kindle wasn't included in the email so I wrote directly to them and asked if an app for using Incredimail with Kindle Fire HD was available. Here's the reply I got (pasting): Thank you for using our Incredimail app. I will be happy to assist you in any way that I can. Please note that the Incredimail app is compatible only with iPad 2 (or above) and iOS 6 (or above), however, we will definitely consider adjusting Incredimail for other devices and operating systems in the near future.
We thank you for choosing Incredimail.
Best regards,
Maria Goldshtien
Incredimail Support
So there's the answer. No incredimail for Kindle Fire HD yet.
Mar 21, 2013 | Computers & Internet
When advised [repeatedly] by Incredimail to update my version Of Incredimail 2, I finaly get a error 2738 could not access VBScript runtime for custom action. Any one help?
Microsoft has created a Fix-It for this!
What this Fix it does is to remove incorrect or corrupt registry entries that interfere with VB support in windows and then re-registers the DLL ensuring that the correct registry setting are there. After running the Fix it solution you may be able to immediately try the operation that previously gave you the error, but to be sure, a reboot is suggested. This will address similar issues with other programs as well and not just the applications that are specifically mentioned in this thread.
The link to the Fix it is: http://go.microsoft.com/?linkid=9804433
If you want to do it without any software then here is the Link to view the solution ERROR 2738
Aug 04, 2012 | Microsoft Computers & Internet
Cant send or receive emails with incredimail or outlook express for some reason
1) Make sure you have a good Internet connection, make sure you can access a web page, any will do.
2) Assuming you've got a good connection, you need to go through your email set up/connection settings carefully again. I mis-spelled password or name will cause failure.
Jun 04, 2012 | IncrediMail
Stop incredimail
Uninstall IncrediMail 1
  • Click on the "Start" icon and select "Control Panel"
  • 2 Click on the "Add/Remove Programs" or "Programs and Features" icon.
  • 3 Allow the program list to fully load; this may take several minutes if you have a lot of programs installed on the computer.
  • 4 Click on the icon for "IncrediMail" and click on the button "Uninstall."
  • 5 Confirm in the pop-up window that you wish to remove IncrediMail and all of its components from your computer.
  • 6 Wait for the uninstall process to complete, a success message will appear on the screen.
  • 7 Restart the computer.
  • Removing IncrediMail Components
  • 1 Click on the "Start" icon and choose "All Programs."
  • 2 Scroll down the list until you see a folder for "IncrediMail."
  • 3 Right click on the "IncrediMail" folder and select "Delete."
  • 4 Confirm you wish to delete IncrediMail, a window will pop-up showing the transfer of files to your trash bin.
  • Performing Disk Cleanup
  • 2 Click on "Accessories," "System Tools," and click on the "Disk Cleanup" icon.
  • 3 Select "Scan Local Drive (C:)" and allow the process to find all removable files.
  • 4 Place a check mark next to "Downloaded Program Files," "Temporary Internet Files" and "Temporary Files."
  • 5 Click on "OK" to confirm the deletion of the folders, files and any leftover traces of IncrediMail. The process will complete and a window screen will show a successful cleanup message. Restart the computer.
  • Cleaning Registry Files
  • 1 Click on the "Start" icon.
  • 2 Click on "Run" or click on the start search field at the bottom of the screen. Type in "regedit" and double click on the icon that pops up.
  • 3 Double click on "HKEY_CLASSES_ROOT" and then double-click on the "Applications" folder.
  • 4 Right click on on "Incredimail" and choose "Delete." Right-click on "Impcontent.exe" and select "Delete."
  • 5 Close out the registry window. Restart the computer.
  • Dec 07, 2010 | Google Gmail
    I uninstalled incredimail but it seems to appear when I open onto google.How do I get rid of it altogether?
    1) Click on Start, Settings, Control Panel
    2) Double click on Add/Remove Programs
    3) Find "Incredimail" in the list of installed programs and click on Change/Remove to uninstall it.
    Problems with Uninstalling Incredimail:-
    Unfortunately, when the normal procedure for uninstalling Incredimail does not work, it can leave parts of Incredimail still intact.
    Here is the list from Microsoft of the items in the registry that should be removed.
    In run command write regedit and pless Enter
    Under the HKEY_CLASSES_ROOT key, delete the following keys: \.ima \.imf \.imi \.imn \.ims \.imw \Applications\Impcontent.exe \Applications\Incredimail \Incredicontent \Incredimessage b. Under the HKEY_LOCAL_MACHINE key, delete the following keys: Software\Classes\.imc Software\Clients\Mail\Incredimail Software\Elishim\Protect\Browser (remove the Incredimail value) Software\Incredimail Software\Microsoft\Direct3D\Most Recent Applications\ (remove the NAME value that points to Incredimail.exe) \Microsoft\Windows\CurrentVersion\App Paths\Incredimail
    c. Delete the HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs\Incredimail key.
    Oct 06, 2010 | Google Chrome
    Incredimail xe
    I fixed it! Go to the Programs & features in control panel (in Vista), XP users go to Install/Uninstall programs. Highlight Incredimail & click on Uninstall, A dialogue box will appear that gives you the option to uninstall or repair. Click on repair and wait for Incredimal to finish repairing. Incredimail should now work.
    Good Luck.
    Apr 04, 2008 | NewSoft Presto! PageManager 6.0 for PC
    Computers & Internet Logo
    119 people viewed this question
    David Payne
    David Payne
