Question about HP Officejet 5610 All-In-One InkJet Printer
Computer doesnt reconise my printer fax copier scanner
I have gone to hp and installed the drives but it still doesnt work
pls help
  • Anonymous Jan 21, 2009
    I have Windows vista on my computer and my all-in-one keeps disconnecting from the computer and now it wont recognize it...i have the disk but it says it's for windows 2000 and XP...is there a way to make it compatible with Vista?
HP P
Posted on Jan 22, 2009
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
Computer prints to hp 2575, but computer will not detect scanner and scanner will not detect computer. what to do?
open control panel and go to Scanners and Cameras check any scanner driver is there what .....try to use the driver if its not working install the all software for the printer and check ..............
Dec 14, 2009 | HP Photosmart 2575 All-In-One Printer,...
Scanner won't work
did you try the copier function?if you can copy documents then the scanner is good,well if it wont works you cant print neither..but as you said you get a print out.reinstall it carefully and slowly..the logic board has no problem,just focus on the driver..
Sep 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner says I need to install software
To make your scanner work use HP image Zone (included in your install cd or downloadable from hp's website)
Hope this helps
Jun 27, 2009 | HP Photosmart 2610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
I do not know how to scan,or set up my hp 4315v all-in-one printer. Can you help me?
Click on "control panel" on your computer, click on "printers and faxes", click on "install printer" (left of screen on my program). Then the installation Wizard should come up and follow its instructions.
Whether or not you have to go to "scanners" (same page as "printers and faxes") I'm not sure. Do the first steps I have listed for a start and if scanner doesnt work use scanner wizard. Hope that helps. Good luck.
Apr 04, 2009 | HP Officejet 4315 All-in-One Printer
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
May 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
