Question about Sony SnapLab UP-CR10L Digital Photo Printer
Two lines show on my 5x7 prints
When printing a 5x7 two lines show on the prints running the lenght of the print. Can't find instructions on how to use cleaning sheet or if this would help
    Problem Solver:
  • 5 Answers
If the machine has mainly printed 6x4,When you
go to print 7x5 the edges of the head and rollers
tend to be dirty and will leave the two stripes along
the edge of the prints.Use the cleaning ribbon and the
sticky pad supplied with a new box of paper to clean the machine.Depending on how bad it is it may take a few try's.To do this switch the machine on and enter the control panel by tapping twice on the top left of the monitor- It will ask for a four digit code - Uless it has been changed this will be 9999 click
Enter/Ok - then click on the top far right ikon and
the screen you see will have a greyed out ikon
bottom middle - Now replace the print ribbon with
the white cleaning ribbon supplied with the machine
and the greyed out button becomes active - Click on
this button and the machine asks if you want to clean
it click Enter/Ok - About 10" of paper will then be
driven from the machine place the sticky pad as per
the drawing on it onto the paper and press Enter/Ok
- The paper will move in and out a few time and then eject a big piece and some small pieces of paper - Then remove the white cleaner ribbon and replace with the print ribbon and press the green return button
in the bottom right of the screen to return to normal use.This should be performed every two - three boxes
of paper.
Posted on Oct 26, 2009
Print set up in the program
You do not specify what Epson Printer you are using. I have an Epson WorkStation. The Document Format in the Principal (Main) tab of the printer parameters lists among other format, a personalized (custom) format where you can choose the dimensions in mm or inches.
Nov 22, 2013 | Arts & Letters Arts and Letters Express
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
Faint white line observed on print
nope, the TONER OR INK CARTRIGE is running out in tat area, so you have to check it so that there is a new one. hope this helps. :)
Dec 08, 2007 | Minolta magicolor 2350 Laser Printer
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
248 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
