Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Gas fireplace works great, just can't find a serial number to order the compatible remote for senior citizen to use. The wall switch does not turn on/off the unit. I have to crawl down to knob to start igintion. diana
    Novelist:
  • 88 Answers
Thanks Diana for the Question,
the info you are looking for , sorry to say, should be in the service area of the fireplace, yes it means back down on your knees, but if I were you I would have a friend, or someone a little younger take a look for ya, as far as the wall switch, it could be one of three things, either the switch has been disconnected, or there should be a switch near to were you have to manually lite the unit that needs turned in the opposite direction, or the wall switch has to much resistance to let the small amount of voltage necessary to operate the fireplace, Heat and Glo makes a good thermostatic remote, but I would call your local Heating and A/C company to get an estimate on cost for the remote and Install, you may want to call them and have the switch looked at, might be a lot cheaper, best of luck, hope that helped, let us know how I did for ya, thanks again,
mr.grzz
Posted on Jan 21, 2009
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Need some troubleshooting tips on a fireplace. I've got the pilot on but when I flip the wall switch nothing happens.
Most of these unit are controlled with a millivolt signal that is generated from the thermopile.
We see this often at the beginning of the year.
Remove the wires from you wall switch and clean them so you have new metal showing and tighten them back to the wall switch.
With your gas valve in the on position try the switch.
If this doe not work do the same thing to the wires on the gas valve where they hook to the TP/TH connecting and the Th connection.
More information can be found at www.allpartsinc.com
Nov 05, 2014 | Leisure HOMEPRIDE Electric Fireplace...
What thermostat will work for my gas fireplace?modelwh060396b 07/2006 has remote want a wall mount
A search for that model number did not yield any results. A brand name would help.
That said, if your gas fireplace has a milivolt valve with "TH" and "TP/TH" terminals on the side (for hooking up a remote, thermostat, or switch), then you can use a universal wireless wall system.
You can find wireless wall systems for gas fireplaces HERE.
Dec 23, 2012 | Heating & Cooling
The 5th button on the remote is flashing from letters to numbers and I do not have a manual to see what it means, where can I get a manual for my Dimplex SOP-270-O - Ovation Heritage Leaf Oak Fireplace
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall outlet and wait 12 to 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and try manually operating the different functions. If everything operates as it should, put the switch on the fireplace into the Remote position to see if your remote will take back over and function as it should. It is continues to do this contact Dimples USA Technical Support at 888-346-7539 for further instructions. Have you Model # and Serial # Handy when you call.
Mar 18, 2011 | Heating & Cooling
We purchased a home with an electric start/gas fireplace...no owners manual...we turned on the gas with the key, flipped the switches on the wall and the fireplace unit...we see the ignitor clicking and a...
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Oct 19, 2017 | Leisure HOMEPRIDE Electric Fireplace...
I have a Marco Natural Gas Direct Vent Fireplace that you turn on with a wall switch. Lately it will not light when the switch is turned on, this happens about 50% of the time. It is not the switch because...
The only thing a fireplace like your has that could be faulty is the thermocouple or safety switch on the gas valve.
A thermocouple is a likely suspect. Look in your manual for a part number and buy a replacement. Cleaning the old one might work too if it is heavily coated with carbon.
Dec 16, 2009 | Leisure HOMEPRIDE Electric Fireplace...
I just bought a Lennar home in the Hanford area. It was a foreclosure. There is a Heat n Glo doublesided fireplace. No manual for operation. How do I get the thing started? There is a red gas valve on the...
i would really suggest having a gas log service company come out . 2 reasons 1st it should be maintenanced every year and 2 its a gas appliance have a qualified person explain the operation visually
Nov 28, 2009 | Leisure HOMEPRIDE Electric Fireplace...
I cannote get my remote to operate the fireplace. I have installed 3 new batteries and it still does not work.
The remotes are often a problem...I would advise against repairing it....sometimes the sensor for the vent isn't visible enough for the remote...the wires or sensor can be melted....The best/cheapest solution is to run a wire from the same two contacts the remote sensor are hooked up to on the gas valve...and install a switch on the wall....Turn the fireplace on with the flick of a switch....a Thermostat can also be connected to operate the fireplace using the same contacts as the remote
Oct 26, 2009 | Desa International Unvented Gas Space...
Soot on glass,outside vent and on walls of fireplace
you have a problem with combustion.unit is not burning properly you should turn unit off and call a pro the life you save may be your own
Apr 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Trouble "lighting" our Majestic fireplace
Your thermophile needs replacement most likely.
Here are 2 pages of good info
thermophile operation
Oxygen depletion system tips
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
