Reset button on tp link sc4171g - Computers & Internet
One of my TP-LINK 500Mbps has stop working .What can I do to fix it
I have to assume you are referring to TP-Link power line adapters. In any event, pick the one that is not working. Press and hold the Pair button for a second or so, the Power LED will start flashing. Wait 2 minutes, then press and hold the Pair button of your main (other) TP-Link for 1 second, the Power LED will start flashing. In about 2 minutes all should be good.
If not you may have to reload the flash software or use the disks to reset.
Cheers
Jul 13, 2017 | TP-LINK Computers & Internet
Clear password router
Try pushing the button for 10 seconds or more, because 5 seconds would be for wps or emergency firmware reload(like for a corrupted firmware).
Jul 02, 2014 | TP-LINK Computers & Internet
TP-Link TL-WR841N Wireless-N300 Router dropping connection
Do you experience problems with other WiFi hotspots?
Dec 12, 2013 | TP-LINK TL-WR642G Router
Www192 168 1 1
reset button on back, press and hold to reset to factory setting
May 02, 2013 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I cant remember the password of our wifi pls help here's my email...tnx!
You can reset to factory default by pushing and holding the RESET button for 30 seconds or so, release, that will restore the device to the factory default settings. Connect and reconfigure the SSID and Security Code. You may want to write down the Password for future use, just a thought. For info: http://www.tp-link.com/Resources/document/TL-WR740N_741ND_User_Guide.pdf
Dec 24, 2012 | TP-LINK Computers & Internet
Cannot access my tp link TL-WA601G 108M Wireless Access Point
Use the Factory Default Reset button: First, turn off the AP's power. Second, press and hold the default Reset button then turn on the AP's power, until the system LED lights up (about 3 seconds). Last, release the reset button and wait for the AP to reboot.
Reset the factory defaults.
Here is your user manual:
http://www.tp-link.com/english/soft/20091515618.pdf
Default username and password is admin for both
May 20, 2012 | TP-LINK Computers & Internet
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
Reset the router
1. On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
2. If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
3. If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Jul 09, 2011 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I have a tp link TLWR642G router and i can't reset password. I try to do this from the reset button but its useless in any way. The problem is that it cannot accept admin as password. Is there any change...
Most likely the telephone company would not have reset your router, unless they provided it to you.
See this article: http://www.tplink.com/en/support/viewArticle.aspx?id=83
Make sure you are holding the reset button down long enough that it reboots itself and see if that helps. I have come across several times, where people have not held the button down long enough.
Good Luck
Mar 28, 2011 | TP-LINK TL-WR642G Router
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
