Question about Sharp EL-531VB Calculator
Calculator will not recoginize decimal and double 00 keys
I have been able to use the decimal key to put in a date 1.21.2009 but it not longer does this. I don't know if someone flipped any of my positions on the mode selectors and where they should be.
  • Sharp Master
  • 7,993 Answers
The EL-531V and EL-531VH calculators do not perform any computations on the date. Since I could not find the manual for the EL-531VB I cannot vouch for it. However, if it is a scientific calculator, it does not handle dates, but you can always press any sequence of keys, it is not guaranteed that it makes sense for the calculator.
Hope it helps.
Posted on Sep 20, 2009
Broken decimal Key
the button can be replaced if you can find a tech, but once they start going it'll be one thing after another. Better to just get a new one.
Who the Hell uses a Calculator any more?
Apr 15, 2014 | Canon Mp25dv Desktop Calculator 8077a006ab
Desplay showing 0.000000 00 help! I don't know
The calculator is set to scientific notation. To change out of it, press and release the f key then the decimal point key and then a digit key representing the number of digits you want to the right of the decimal point.
Feb 15, 2011 | HP 12c Calculator
1.000000 00 want to clear
You're in scientific notation. To change out of it, turn the calculator on, press f then the decimal point key then a digit representing the number of decimal places you want after the decimal point.
Jan 12, 2011 | HP 12c Calculator
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Date and time reset
To set the time: First set to Rate to "SET" then say for example the time is now 1:33 p.m. enter 13 then hit the decimal then enter 33 hit the decimal then hit the time key and you are set.
Jan 22, 2010 | Sharp EL-1750PIII Calculator
How do I set the date and time on my EL-1801V calculator?
Push the button at the top over from GT to SET.
type the date in using the decimal as a spacer.
Then press the date/time key.
for the time...
Press the date/time key until the date shows,
then enter the time in military time and press the date/time key again.
Dec 01, 2008 | Sharp EL-2630P Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
Set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
Nov 27, 2007 | Sharp EL-2630P Calculator
Sharp EL-531VB Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
