Question about SIRIUS XM Radio XM SkyDock
Xm skydock slow load - SIRIUS XM Radio XM SkyDock
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Skydock won't play iTunes through the radio like it does for the satellite radio. The song plays but no sound comes from anything other than the XM Skydock App.
hi donald!
it seems like you haven't properly installed the sky dock yet.
can you tell me the model of the sky dock you purchased?
Mar 30, 2011 | SIRIUS XM Radio XM SkyDock
I have a Kenwood ddx6019 with XM satellite radio. recently, I entered a manual channel change and lost all reception. A banner reads LOADING LOADING across the bottom of the screen. Any ideas on how to...
I have a Kenwood ddx6019 with XM satellite radio and sirius. i want to know how do i turn on the xm so i can get live traffic update and my garmin gps unit and weather. and were to i find the mx radio id for xm. i found it for sirius
Nov 01, 2010 | Kenwood DDX-6019 Car DVD Player
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
My 2008 Hyundai Tiburon XM radio just says "loading". Subscription is active.
Disconnect the negative battery cable for 10 minutes and reconnect. Most of the time this will reset the XM set top box and all will start to work properly.
Jul 02, 2009 | XM Radio (XMP6000)
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
May 26, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Xm radio
it might be the signal is out of range gotta love xm signals once detects the signal things should go back to norm
find xm antenna try to follow back to unit see if it just came loose from bumping it
a good reset way is disconnect from power let set for a minute or 2 and then plug back in
radio id should be xm compliant the sterio your using to push the sound you need that id
May 06, 2008 | Car Audio & Video
SIRIUS XM Radio XM SkyDock Logo
73 people viewed this question
Top SIRIUS XM Radio Apps Experts
Bill Boyd
ray gallant
Are you a SIRIUS XM Radio App Expert? Answer questions, earn points and help others
