Question about Bosch Classixx WFL 2066 Front Load Washer
Unable to remove!
I have uncrewed the black outer seal (anti-clockwise) but inside there is a white "plug" when outer seal removed water leaks out but you cannot clean filter!!!!!!!!
  • bren&izy2 Jan 25, 2009
    Cheers pedropony2
    I managed to tease white part out as you sugested, then remove the obstruction!
    Thanks again
  • cela321 Feb 13, 2009
    aha, I have similar problem. I removed the black seal & found a sock. Now the washer will complete the drain/spin cycle w/o E04 error, however, there is a lot of leaking from underneath (bottom of lip of black cap when the drum drains. (I did tighten the black cap as tight as it would go.)
    I suspect I have to try & remove that white cap to see if any further obstruction--how do I do that? Also, I have a black gasket about 1 1/2" diameter that came off of something when I removed the black cap. I've tried to fit it on the end of the black cap but not really sure where/ how it goes on. Can anyone explain that gasket to me? Thanks!
  • 135 Answers
The plug you described is supposed to be atached to the piece you have removed.
You will have to tease the plug out with a small flat blade screwdriver.
Hope this helps.
Posted on Jan 22, 2009
Elite model #11027087603. How do I remove tubseal nut on bottom of washer that holds motor rotor on shaft?
that should have an inset, hex-headed screw/bolt. You will have to hold the rotor with one hand and use your other hand to loosen that screw. they use thread lock on that screw, so it will be difficult. but, that's only half the battle. You will have to remove the tub cover, agitator (7/16 agitator nut size), and the spin basket to access the tub seal. the seal has to go on from the inside of the tub assembly. Make sure you don't use anything against the outer lip of where the seal seats inside the tub, or you will have to replace the outer tub because it will still leak. Push the seal all the way down. then before you put everything back together, pour a small amount of water in the tub and see if you see any leaks. anything major will show then, but if there is a small leak, you will not know it till you try to wash with it. You shouldn't have to remove the stator screw or do anything from the bottom side of this unit. You should be able to replace that seal from the top side. good luck.
Nov 28, 2015 | Kenmore Washing Machines
Samsung frontload washer
Put small black hose in a container and remove white plug to drain excess water, unscrew large white plug anti clockwise and pull filter out and clean.
Jun 11, 2013 | Washing Machines
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
Unable to open pump fillter
Remove the kickstrip, front of the appliance. Unscrew the pump filter by rotating it anti-clockwise, A little water may leak from the pump: this is perfectly normal. Clean the interior thoroughly, removing any visible debris. Refit by screwing the filter into place.
Jan 04, 2012 | Hotpoint Washing Machines
Leak air for the trigger
Could be leaking from trigger or in front of trigger at plunger. Spray soapy water on area and determing exact leak. If from trigger pin, remove pin holding metal trigger (3mm roll pin) and check white plastic plunger for oring on groove. If oring is in place then check vinyl ball inside trigger valve bushing. Replace as needed. If leak is in front of trigger at black boot, remove head and replace oring on outer part of cylinder plate (donut shaped plate at top). Good luck
Mar 01, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
Where is the drainedge for the radioter
For a 2001 Buick Regal GS 3.8 Liter, Supercharged engine:
First, let engine cool some. Second, locate small drainage hole at the bottom left/drivers side, of the radiator. From the bottom of this small drain hole, go straight back toward rear of radiator, then up about 1 1/2 to 2 inches up. (Have a drain pan or pail handy, to catch the old antifreeze.) You'll find a dark colored drain nut. Use a larger, correct sized socket ratchet wrench & loosen this fitting a turn or so, counter clockwise. Old antifreeze will begin to come out the bottom drain hole. The more you loosen the fitting, the faster the fluid flow out. I wouldn't remove the drain plug completely, or you'll loose control of the draining flow rate.
I just changed my anti-freeze just last week. I also changed the 2 large radiator hoses & smaller 2' overflow hose at the same time, as long as I was doing the job. They had never been changed before. I also used new hose clamps & a small packet of "radiator hose grease", from Autozone.. I drove the car up onto front car ramps to make it easier. I used safety jack stands for extra care. " You-Tube" shows some, "how to videos", that are helpful.
The old hose clamps are difficult to get to. (You'll need a few tools, some time & patience.) To get to the upper clamp, near the right/passenger side of the of the car, near the battery, I removed the outer serpentine belt & tension pully. I then removed the factory installed spring tension clamp, with the help of an adjustable battery pliers. The bottom of this hose wasn't too bad to get to. On the left/drivers side of car, remove black air intake box to access upper clamp. Remove the black metal brace bar, the will allow access to the air intake black box.
I also changed the small overflow 2 foot long hose & 2 clamps, that goes from radiator cap area, back to the overflow white plastic tank, close to passenger firewall. I removed the overflow tank to clean it out as well. I drained the fluid & changed the 3 hoses & clamps. I then placed all removed parts back where they belong, including white plastic overflow tank, tension pully & outer serpentine belt, air intake black box & metal diagonal brace, contacting air intake box. I flushed the system with some Prestone Radiator Cleaner & clean water. Start car & get up to temp., then run for about 10 minutes. Let cool, then drain again. I flushed my car at least 2-3 times after this, until the drain water ran clear.
The best price on a 5 year/150,000 mile anti freeze, came from Wal-Mart. I then mixed about 50/50 with Distilled water, as suggested on the bottle. All went well & no leaks! I took my time and did a thorough job. Good luck!
Jan 16, 2011 | 2001 Buick Regal
Battery replacement
Hi.
Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Here casio page for this model:AMW320R-
Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
1999 gmc suburban has water loss
Good chance that it will be a bad heater core if your floor boards are getting wet, but has the inside of your windshield been fogging up. Most of the time when a heater core goes bad, the inside of the windshield fogs up. If the leak is not that bad, you can add 2 to three table spoon of common kitchen black pepper. The Black pepper will work it's way to the leak and plug it up till your can have it repaired properly and the black pepper will clean up easily when the cooling system get's flushed. Good luck and this should by you some time so you can work on it in the summer. Don't use any radiator stop leak, they just make a mess to your cooling systems water ways.
Jan 29, 2010 | 1997 GMC Suburban
Noisey during spin
yes you are right noise during spin cycle is due to faulty bearing. If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 07, 2009 | LG WD-16115FD Front Load Washer
Amana washer model LW6501W2 leaks in front during fill up
During fill only
All the time
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Bosch Classixx WFL 2066 Front Load Washer Logo
106 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
