When I start my sekonic on the computer an error message on the screen says Screen number Frm Main Object name fGrtlnispring() Subfunction name setmenu caption() Error nimber 339
SOURCE: meter is consistently a half to a full stop off
I've known this problem to occur if the wrong kind of CR123/CR123A lithium battery is used. They come as rechargeable and dry cell (i.e. non-rechargeable) versions. For sensitive devices like yours the difference is important as the internal resistance of the rechargeables is lower which affects the voltage characteristics.This meter is designed only for the dry cell version: see page 34 of the user manual, although the instructions don't make this fact clear enough IMHO. The reason for using the dry cell version is that the output voltage remains constant until the battery is nearly exhausted, but the rechargeable version starts at a slightly higher than nominally rated voltage and drifts down as the battery discharges. This means that you only get a truly accurate reading with a dry cell battery. There is no user adjustment to recalibrate the meter but you can use a different ISO rating to compensate or use the exposure compensation settings.
SOURCE: Sekonic L-358 light meter will not trigger my
Hi Liz
have you checked your sync cable?
tried meter on another system (for comparison)?
Depends where you are.. Mamiya in the USA can solve the problem.
SOURCE: how to use a sekonic l-758dr lightmeter
This is the link to the PDF manual: http://www.sekonic.com/upload/files/L-758_Operating%20Manual_English.pdf
Cheers, hope that helps!
SOURCE: Re: Sekonic L-328. Sometimes the
You could be having a switch problem, or another intermittent problem. Most the the switches on devices these days require that the unit be disassembled to clean them, and that's tedious. You should call Sekonic and see if they can help, or service the unit.
Good luck, and hope this helps.
