Bartender error 3700 for ZEBRA 400 - Office Equipment & Supplies
2 Suggested Answers
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Why wont my zebra printer print
You can avoid the issues just downloading for free a driver pack for your printer at www.nicelabel.cl (you will just need to enter an email and will get it free at downloads)
Oct 15, 2012 | Zebra S Series 160S Thermal Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the...
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
May 25, 2011 | Zebra 105Se Thermal Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Mar 09, 2009 | Zebra Z4MPlus Printer
I have a Zebra 160s lable printer & i want its installation S\W
You can use software such as Label Matrix, BarTender, EasyLabel or ZebraDesigner (free on zebra.com).
Jan 17, 2009 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
k24674
jasbo
jasbo
