Question about Rinnai Water Heaters
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
RU98i, code flashing 79 and beeping. what does this mean??
    Problem Solver:
  • 27 Answers
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Posted on Jul 16, 2013
My Rinnai tankless water heater flashes 11 when calling for hot water.
Your Owner's manual should help. No manual, try MFG website, or email their customer service. Or try manualslib.com
Apr 27, 2015 | Rinnai Water Heaters
Where is the leak sensor located?
Rinnai V65iN Installation Instructions and Product Brochures . Please school to the bottom of this link. You find a directory which includes technical manuals and support. Provide the information. And someone will get right to you. You probably fixed it by now. Here is your sourcing.
Apr 28, 2014 | Rinnai V65i-N Internal Natural Gas...
How to fix Rinnai code 79
Let it dry out.
If it wont fire because of the error, try powering it off and back on. Also being new, it would be under warranty
Jul 20, 2013 | Rinnai Water Heaters
How do you fix rinnai tankless water heater code 79
Do not spend 500 on plumber to determine that condensate drain was not installed properly on vent line, and that acidic water from combustion by-product has been dripping down into tankless and burning hole through the special-alloy heat exchanger instead of going down into floor drain and corroding your plumbing pipes.
Do not spend hours fulfilling the required monthly and yearly maintenance, or spend money on service call each year to get the burner cleaned and gas pressure checked on your tankless computer that heats water...
Instead, fix any tankless problem, any brand tankless, same day do-it-yourself for $385, by replacing 1 part: the whole thing:http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Gene
Beep codes
Get the manual for it on line and look up the beeping meaning and the reaqon for the priority lite.
May 24, 2013 | Rinnai Water Heaters
Water does not stay hot
Had this trouble with a condensing boiler,water pressure was too low, also if thereis an adjustable stat try turning this up ?
Jan 26, 2013 | Rinnai RU98i-N Interior Natural Gas...
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
Jan 20, 2013 | Rinnai Water Heaters
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
1,251 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
