Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Motor won't start, makes buzzing sound, motor won't kick in
The motor will not kick on, it makes a buzzing sound, when it is turned on.
  • Anonymous Jan 26, 2009
    motor wont start makes a buzzing sound
    Scholar:
  • 84 Answers
Sonds to me like something is stuck in the impellaer
did a glass break in the machine lately or possible some food got stuck worst case the motor start capacitor has given up the ghost so to speak.
Posted on Jan 21, 2009
Indesit Dishwasher LS12-E2100. Lights work in door and there is a buzzing noise when the door is shut, but it won't fill with water, so it will not work.
Generic step 1: Clean the internal filter.
There are manuals and troubleshooting guides online. Go find them.
The buzzing noise may be a symptom of the problem. If the main motor cannot turn, it will stall and buzz. With the power disconnected and the unit pulled out, try to turn the main pump motor from the bottom (They are invariably in the center of the
unit on the bottom of the wash tub). If that turns freely, something else is buzzing which may or may not be a problem. Try to find out what is making the noise. Note: If you cycle the unit with it pulled out, it will be obvious if the motor can turn or not.
An old mechanics trick (Old trick, not mechanic): With the unit pulled out, and exhibiting the problem: Take a 1/4" wooden dowel (do not use metal!!) and press it against the little flap of your ear so as to cover your ear canal. Do not insert the dowel into your ear! The dowel will mechanically conduct sound to your ear. Now, with the dowel on your ear, probe around the bottom of the unit, listening to find the loudest buzz. You will quickly get the hang of it.
When you have found what is buzzing, you may have found your problem. You may not recognize whatever you find is buzzing. Consult the online documentation.
The buzzing may be the water inlet valve. It may be the pump motor that has ingested something that keeps the motor from turning. It may be something else.
I am guessing that the buzzing is not good, but it could be benign. When you have found the buzz, consult the manuals & troubleshooting for further instruction.
I have the feeling that this problem will ultimately be resolved by a service tech., but good luck anyway
Pete
Jan 30, 2015 | Indesit Dishwashers
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
My Whirlpool dishwasher won't drain and won't start, it makes a slight buzzing sound then clicks off...
While this could be a number of problems, I'll start by asking how old is the unit?
Jul 09, 2011 | Whirlpool Dishwashers
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
heatman101
Apr 23, 2011 | KitchenAid Dishwashers
Kenmore elite dishwasher making loud buzzing sound when washing
it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
Feb 21, 2009 | Dishwashers
Makes a loud buzzing sound when washing
This buzzing sound can be from a couple things. A lose a lose kick/access panel when the motor and pump is in operation can cause a slight vibrating noise. Try tightening securing the dishwasher and kick/access panel.
Second, (most likely) their can be an obstruction or debris in the water pump. You may see a plastic grid (4" x 6"; filter like) in the right rear of your dishwasher; Try removing the grid (1 or 2 screws 1/4"/cross tip), then use a dry-vac to remove any debris. *
Safety: As a beginning, please remember to perform the repairs with the power-off and ensure you have water in the dishwasher before restarting the water pump cycle (the water-pump can become damaged while dry-spinning and water enters the pump suddenly)
Jan 26, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Diswaher fills with water and then I hear a buzzing sound on the capacitor next to the motor. The motor does not turn on to spay in the dishwasher.
Hi tonyh514,
I'm Harvey the Master Plumber.
Your problem is: Diswaher fills with water and then you hear a buzzing sound on the capacitor next to the motor. The motor does not turn on to spay in the dishwasher.
Sorry, it sounds like the motor's starting capacitor has failed. The unit must be removed from the cabinet to allow for easy access. With some models you can change it out, others you change both the capacitor and motor. I don't recomend this repair to the average homeowner. You might consider the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 15, 2008 | Dishwashers
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
277 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
