Question about Brother MFC-5840CN All-In-One InkJet Printer
All in one error
Error message when restarted....UNABLE TO SCAN..... it will not allow me to use any functions at all. just prior to this I was trying to send a fax, 1 sheet jammed and I was able to grab it and straighten it enough to finish going through. But then I got this error message...any ideas?
  • 35 Answers
Hi. I researched your issue and found help on the Brother support website. Follw the instructions provided by the following link and your error should clear... Hope this helps. Good luck.
Posted on Jul 03, 2007
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Unable to write the file to "Destination Folder"
A recent (Dec 2015) Windows 10 update seems to have removed the access required for the service account used by Brother to write to the hard drive. This fixed the scan function for me...
  1. Navigate to the directory where you write the files (C:\Users\YourID\Pictures\ControlCenter3)
  2. Right click on the Scan directory and open Properties.
  3. Click Security tab.
  4. Click Edit
  5. Select WMPNetworkSvc
  6. Allow Full Control
  7. Click OK
Nov 11, 2011 | Brother MFC-6890CDW Printer
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Unable to Scan
Remove the TWAIN software and reinstall it. Best if you can use the add/remove software in the control panel. You might want to look in the Device Manager for the USB entry that controls the device and remove that. If you find it open with an error, definitely remove that entry.
You might want to check with Brother to see if they have a updated driver for your 5840.
Thanks for your question at
Jan 01, 2010 | Brother MFC-5840CN All-In-One InkJet...
Scanner won't allow me to use scan to button
To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software must also be installed and running on your computer prior to scanning. To verify that the HP Photosmart Software is running on a Windows computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower right side of the screen, near the time.
NOTE: Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
Dec 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Errors when scanning via all methods
You just didn't set up the scanner function, please reinstall the software and restart before you use the scanner.
May 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Error Message: Scan Unable A6
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-5840CN All-In-One InkJet Printer Logo
63 people viewed this question
James Cagle
James Cagle
Jim Keysor
