Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
There is no power
I was given this scooter thinking it only needed a charger and new batteries. (I can not afford to buy a scooter) I bought new batteries and there is still not any power. The meter does not move or anything. I have checked the fuses that I know of, in with batteries and inside where the key goes. I have continuity from the key to the positive post. The scooter has hardly been used. It still has the rubber tips on the tires. The person that gave it to me said it ran until he thought the batteries died. Have any ideas? I would greatly appreciate it if you did. Thanks
  • sims659 Jan 28, 2009
    The biggest help was using the jumpers. I found a bad conection where the batteries set on the post. I think it was front lack of use. I have running now. Thank you so much with the help.
  • 95 Answers
Seems like you are on the right track and you can save alot of money there. I would aproach this systematically trace the power to the switch then t0o the speed controller and back to moter you can also put some jumpers from a battery to the moter connections.
If it is in such new condition then it must be a damaged or loose connection.
Posted on Jan 25, 2009
I have a infinity four and when plug in to the mains it charges but when unplugged it dies the lights all come on but no power what do you think it's the battery ?
Most likely. You can try this before you buy new batteries. Take them both out of the scooter and use an automotive style battery charger to charge them individually. This may take several days for each battery. Reinstall the batteries and try your regular charger to finish the charging. If none of this works, then the batteries are too far gone
Aug 12, 2016 | Health & Beauty
We just bought a used scooter. it uses two batterys. one battery was missing, need too buy new ones how do they get hooked up?
You need two matching batteries and unless you are satisfied that your existing battery is retaining a satisfactory charge you should by two new batteries that are compatible both with your scooter and with the charger. New chargers are not expensive however, a faulty or inappropriate charger may well damage expensive batteries.
Jun 15, 2014 | Pride Health & Beauty
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
Nov 18, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Aug 16, 2010 | Razor E300 Scooter
My battery has discharged. I bought a new charger, but it seems to not carge the battery. Any actions or is a new battery needed?
I took my totally discharged batteries into an auto supply store and they left them on their charger overnight. There was no cost for that service and the batteries came back to life and have lasted an additional 6 months. I just replaced them with 12V 15Ah batteries and am getting much better performance now. The total cost for the new batteries was about $70, including delivery.
Aug 12, 2010 | Pride Go Chair Travel Power Chair
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
383 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
