Question about SanDisk Sansa e260 MP3 Player
Problems with amount of memory used...
It says that i have 2.8 gigabytes of music but it says i have used 3.3 gigs of memory. i have deleted all the rhapsody channels, all the demo pictures, the demo video, and i have like 5 megabytes worth of recordings. advice/help is much appreciated.
    Scholar:
  • 155 Answers
Have you tried to format the device? Because they may be some files on the player that is causing this problem. First back up your files before formatting the player. Change the player to MSC mode(SETTINGS>USB MODE>MSC) to format the device. Then update the firmware of the player and transfer the songs back to the player.
Posted on Jul 22, 2007
SOURCE:
Adding memory to PCV-RS322X I have two 1 Gig cards to add and there are 4 memory slots, which slots should they be installed in, fill up one bank or put one card in each bank?
SONY VAIO CAN ONLY TAKE 2 GIGABYTE.YOU HAVE 2 GIG SO I SUGGEST YOU REMOVE YOUR OLD MEMORY AND INSTALL THE NEW 2 GIG IN THE SAME PLACE THAT OLD MEMORY
Jul 03, 2013 | Sony Vaio PCV-RS322X PC Desktop
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
Win Me will not Boot after load. Win 98 will not Boot either. Says not enough memory ???? 2 Gig Memory PC3200-GA-8ipe1000-g Gigabyte MB
Try just using 512Mb of memory or less as there was a bug in Me and 9x that produced that error if you had more than 512 Mb of ram.
Jul 18, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Ive got a nokia 5130c xpressmusic and when i want to use the music player it says "not enough memory" and my web browser doesn't allow me to enter an url it froses.
This problem mostly present in this mobile initially restore factory default settings and check it if the issue is not resolved flash the phone with the latest firmware issue will be solved 100%
Aug 18, 2010 | Nokia 5130 Cellular Phone
My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot...
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Feb 07, 2010 | Computers & Internet
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | IBM PC 350 PC Desktop
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
PS2 HDD Partition Error
A Partition error is the amount of segments that the hard-drive is split into.
For example we have 1 hard-drive Named C:/ Which Is 20 gigabytes. Then we decide that we want to use A Quarter of that drive, solely for saving games On. So 5 gigabytes Will Now Be allocated For Game-saves, This Will be known as Partition 2 Or D:/ So we now have 2 Partitions 1 is C:/ And 1 Is D:/ Partition C:/ is Currently 15 Gigabytes, And Partition D:/ is 5 Gigabytes.
Making a total Of 20 Gigabytes. So if your getting a partition error, it,s either because the game your attempting to transfer Is larger than the Partition, thats trying to receive it. You may be sending 4 gig to a 3.5 gig partition. Or your attempting to send it to a partition that is incorrect or inadequately lettered/numbered.
I hope this enables you to understand, the basics of Partitions on drives.
Mike @ Compurepair.
Mar 04, 2008 | Sony PlayStation 2 (PS2) Console
Deleting
You can manually delete the music thru My Computer. My Computer>Device Name (c250)>Media>Music You can see all of the music by albums and delete what you want. Please add to this question if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
